Associated RC10B44.2 Factory Team kit
12-9-26 14:13| 发布者: rcfans| 查看: 7312| 评论: 9
Associated(AE)的RC10B44越野车已经获得了两个IFMAR世界冠军头衔和四次ROAR全美冠军荣誉。全新的RC10B44.2新车承载着B44车架的优良基因进行了升级改良。加入了Factory Team 12mm大容量避震器(强化避震筒),TiN 3mm避震芯,避震性能大幅提升。升级了的2.5mm厚度碳纤底板,底板长度加长了8mm,宽度收窄了3mm,除了可以提高车架的行走稳定性之外,操控也更灵敏。全新的锂电快速拆装系统、VTS限滑装置都配置到新车上。 JConcepts Finnisher车壳也是标准配置,AE这台RC10B44.2四驱电动越野车绝对是顶尖产品,应有的传统电越设计加上全新的高性能组件,让这辆电越能够征服全球各大赛场。 欢迎进入AE品牌专区参与讨论,->点击这里进入
RC10B44.2 Factory Team Kit Features:
  • Factory Team 12mm 'Big Bore' hard anodized aluminum threaded shocks with TiN "Gold" 3mm shock shafts
  • Updated 2.5mm carbon-fiber chassis +8mm optimized for LiPo saddle packs
  • VTS slipper (variable torque, multi-plate slipper with 3 drive surfaces) assembly featuring a high-rate spring
  • Composite battery trays allow for battery position adjustment with integrated spacers and quick-change battery straps
  • Updated 3.5mm front shock tower and 3.0mm rear shock tower designed specifically for the new 12mm shocks
  • Factory Team 12mm aluminum rear clamping hexes and rear hex wheels
  • Updated front top deck for increased rigidity featuring locking antenna mount
  • Factory Team 7075-T6 blue aluminum 0° rear hubs with oversized outer bearing
  • Updated front suspension arm for increased durability
  • Blue aluminum cam-type motor mount for easier and more secure gear mesh adjustments
  • JConcepts Finnisher +8mm body (clear) and Factory Team protective chassis tape included
http://www.teamassociated.com/pictures/news/articles/993/supporting_photos/B44.2-3Q-Body-OffPR_lg.jpg
http://www.teamassociated.com/pictures/news/articles/993/supporting_photos/B44.2-FT-fullsheet-PR_lg.jpg
    引用 Mini.fans 12-9-28 15:48
    AE总是这么亮  就是配件和英制有些蛋疼
    引用 crusaderlyf 12-9-28 10:43
    抽空看了一下说明,比较奇怪的变化,后轮改用12mm hex结合器,明显现在市面上只有京商有这样的规格,或者田宫较前的DF03有。前轮依然是约10mm的英制规格
    引用 zhukenda123 12-9-27 00:52
    京商应该不至于那么快吧... FS2 SP也不算落后啊
    引用 crusaderlyf 12-9-26 20:16
    zwtnt168: 感觉车壳很难看,伞齿是尼龙的还是金属的?珠差是个致命的弱点。。。。。
    珠差不会是致命弱点,因为电越大部分在于竞技场上,而珠差的强度对于一场比赛是绝对足够的,当然对玩家来说可能珠差的耐用度不够
    引用 zwtnt168 12-9-26 18:12
    引用 阿阿道夫 12-9-26 17:33
    ae的新车看着战斗力不错啊,但是还是喜欢dex410的造型
    引用 2.5R飞了 12-9-26 17:02
    crusaderlyf: 这台电越无疑这段时间可以统领4wd电越市场,但是从.2的版本字样怀疑ae开始吃老本了么,下一个创新的厂商会是谁呢?
    遗憾没加入齿差啊.觉得下个力作应该是 LOSI的...期待...然后可能是 KYOSHO
    引用 crusaderlyf 12-9-26 15:22
    引用 ruanxun123 12-9-26 15:19
    AE的车怎么看都很养眼啊。。
    查看全部评论(9)
