Associated 12mm大容量避震
12-9-17 12:38| 发布者: rcfans| 查看: 5159| 评论: 2
Team Associated推出12mm大容量避震器,CNC工艺制造,强化铝制避震筒和避震顶盖。这款避震AE厂方车手已经进行了长期测试,适合原厂各类型的1/10越野车遥控车使用。包括 2012 Cactus Classic大赛和全美大赛上,这款避震都已经装备在冠军车架上。欢迎进入AE品牌专区参与讨论,->点击这里进入
  • 12mm hard anodized "Big Bore" threaded shock body
  • Titanium Nitride (TiN) 3mm shock shaft with stronger M3 threads
  • Black hard-anodized aluminum shock cap with bleeder screw
  • 12mm two-hole piston (1.5mm, 1.6mm and 1.7mm)
  • Shock shaft hat bushing guide ensures concentric shock shaft alignment
  • Optimized seal gland fit for smooth and consistent performance
  • Factory Team blue anodized aluminum seal gland cap
  • Factory Team blue anodized aluminum shock collar
  • Three spring cup heights (+0mm, +5mm, +9mm offset)
  • Includes mounting hardware and spacers
  • Springs sold separately
NEW! 12mm
784695 913141 #91314 12mm Shock Kit (B4, B44 front — all model versions)
784695 913158 #91315 12mm Shock Kit (SC10, T4 front — all modelversions)
784695 913165/td> #91316 12mm Shock Kit (B4, B44, rear — all model versions)
784695 913172 #91317 12mm Shock Kit (SC10, T4, rear — all model versions)
    引用 马环宇 12-9-18 00:24
    看着不错啊
    引用 rs555 12-9-17 23:14
    哪裡買啊@@
