Team Associated SC10.2 厂队版
13-3-18 14:38| 发布者: rcfans| 查看: 7250| 评论: 5
最近关于短卡的新闻不断,Team Associated宣布将推出SC10.2 Factory Team kit(厂队版)短卡。加入了12mm大容量避震器、VTS限滑离合、Gull Wing前悬挂摇臂、12mm铝制轮圈接合器、蓝色铝制零度尾Hub、珠差和轻量化轴套都是标准配置,车壳是透明款式以便让玩家自行涂装。新车将于下月上市!
点击这里->进入雷虎/AE品牌专区参与互动
Features
- Factory Team 12mm Big Bore hard anodized aluminum threaded shocks with TiN “Gold” 3mm shock shafts
- VTS slipper (variable torque, multi-plate slipper with 3 drive surfaces) assembly featuring a high-resolution spring
- Factory Team 12mm blue aluminum front and rear clamping hexes with hex drive wheels
- “Gull-wing” front suspension arms and updated shock towers optimized for 12mm Big Bore shocks
- Factory Team 7075-T6 blue aluminum 0° rear hubs with oversized outer bearing
- CVA joints with pin retainer clips
- Ball differential with lightweight outdrives
- Factory Team carbon-fiber battery strap with locking thumb knobs
- Updated front and rear body mounts
- Complete set of precision ball bearings
- Factory Team blue titanium turnbuckles, blue aluminum hinge-pin brace, milled motor plate, servo mounts, rear ballast weight, and much more
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/7038_Front_Suspension_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/SC10.2_Top%20Down_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/SC10.2_3Q_R_BodyOn_Rear_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/SC10.2_3Q_L_BodyOn_Rear_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/SC10.2_3Q_L_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/7038_Rear_Hub_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/7038_Shocks_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/7038_Slipper_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/SC10.2_Front%20Hex_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/SC10.2/Factory_Team/photos/7038_Steering_md.jpg
    引用 TRZ 13-3-18 21:31
    坐等4驱版,应该还是皮带车吧。。
    引用 f19811125 13-3-18 19:56
    多少米腻,老款不贵了,这个不知道价位肿么样啊
    引用 只有一个愿望 13-3-18 16:41
    如果4X4改成轴车就爽了。。。
    引用 bassas 13-3-18 15:18
    为什么不是4x4 sc10。2
    引用 糖豆0520 13-3-18 15:07
    沙了个发的 最近短卡真多
    查看全部评论(5)
