Associated RC10B4.2厂队版
13-1-12 23:19| 发布者: rcfans| 查看: 7256| 评论: 2
Team Associated(简称AE)正式推出RC10B4.2厂队版(Factory Team Kit)两驱竞赛级电动越野车。厂队版加入了大量升级零件,包括12mm大容量避震器、VTS限滑、12mm轮圈接合器、+8mm B4 车架和Pro-Line Bulldog +8mm车壳都是标准配置。新车会在2月上市。虽然RC10B4系列已经有一定历史,但是凭借着5个世界冠军和5次全美冠军头衔,可见车架设计和性能表现经久不衰。
->点击这里进入AE品牌专区参与互动
http://www.teamassociated.com/pictures/cars_and_trucks/RC10B4.2/Factory_Team/photos/B4.2-profile-hero_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/RC10B4.2/Factory_Team/photos/B4.2_Steering_md.jpg
Features
  • Factory Team 12mm "Big Bore" hard anodized aluminum threaded shocks with TiN "Gold" 3mm shock shafts
  • VTS slipper (variable torque, multi-plate slipper with 3 drive surfaces) assembly featuring a high-resolution spring
  • Factory Team blue aluminum bellcrank set
  • Factory Team 12mm blue aluminum front and rear clamping hexes with hex wheels
  • Factory Team 7075-T6 blue aluminum 0° rear hubs with oversized outer bearing
  • +8mm B4 chassis and Pro-Line Bulldog +8mm body
  • Updated shock towers optimized for the 12mm "Big Bore" shocks
  • Ball differential with light-weight outdrives
  • Factory Team carbon fiber battery strap and blue aluminum thumb screws
  • CVA joints with pin retainer clips
  • Factory Team rear ballast weight
  • Factory Team blue titanium turnbuckles
  • Complete set of precision ball bearings
  • Factory Team blue aluminum hinge pin brace, milled motor plate, servo mounts, and much more!
http://www.teamassociated.com/pictures/cars_and_trucks/RC10B4.2/Factory_Team/photos/B4.2_Slipper_md.jpg
http://www.teamassociated.com/pictures/cars_and_trucks/RC10B4.2/Factory_Team/photos/B4.2_Shocks_md.jpg
12下一页
    引用 zhousimeng 13-1-13 23:18
    后hub这样设计是出于什么目的?分体的。。。
    引用 颜俊文 13-1-13 10:56
    哪里有卖呢?
