AE推出新车
12-8-23 21:18| 发布者: rcfans| 查看: 6167| 评论: 2
Team Associated(AE)推出两款RTR越野遥控车产品。首先是RC10B4.1无刷镍氢套装版本电动越野车,装备2.4GHz三通道遥控器、Reedy 3300KV无刷马达、XP SC4500-BL电子变速器、Reedy 3000mAh WolfPack电池和一个简易充电器。RTR版本的RC10B4.1和厂队版所有零件通用,玩家可逐步提升车子性能。 车架基于获得4次世界冠军的RC10B4平台研发而成。
  • Built on the 4-time World Champion and 5-time National Champion RC10B4 platform
  • XP 2.4Ghz radio system with SHV1504MG servo (requires 8 AA batteries, not included)
  • Reedy 3000mAh WolfPack battery (#694)
  • XP SC450-BL Brushless electronic speed control with LiPo cutoff, forward and reverse with reverse lock out
  • Reedy 3300kV brushless motor
  • 2.6:1 ratio gearbox with sealed gear differential, dual-sided adjustable slipper clutch, and rubber sealed ball bearings
  • Molded composite low-CG chassis with set-screw antenna tube lock
  • Blue aluminum shock bodies with molded pre-load clips
  • Battery strap with twist-lock thumb knobs
  • Rugged steel turnbuckles for adjustable camber and front toe-in
  • Factory finished Interceptor 2.0 polycarbonate body
  • Pre-mounted tires on white dish wheels
  • Wall charger
另外一款也RC10T4.1无刷镍氢套装版本电动越野卡车,和上面介绍的电越类似,电子设备配置和上面介绍的电越一致。RC10T4车架平台已经夺得7次世界冠军!
  • Built on the 7-time World Champion RC10T4 platform
  • XP 2.4Ghz radio system (Requires 8 AA batteries)
  • Factory finished Interceptor-T polycarbonate body
  • Wall charge
欢迎进入AE品牌专区参与讨论,->点击这里进入
    引用 王玥 12-8-24 17:04
    对2驱不感冒
    引用 跆拳道小子 12-8-24 09:24
    沙发~!好看·····
