发表于 12-5-3 10:02:30 |显示全部楼层 来自: 中国广东阳江
emacemac 高级 Fans 发消息
发表于 12-5-3 15:29:02 |显示全部楼层 来自: 美国
回复 dickyyim03 的帖子
2. 油壓喔~這個好像得複雜呢.還要外孔位上油壓架.我應該做不來.多看文章看看有沒教學!
HPI Europe D8 HARA web page Click into this page and you will see "Part List" and "Instruction". The Hara shock assemblies and tower can bolt straight onto your truck with no modification at all. You just need to make a simple adapter plate out of a small piece of 4mm thick polycarbonate sheet. A hand saw + a power drill +a tiny bit of patience = DONE. But if you are very busy and don't want to fiddle with it, most RC shop can probably do it for you with a small fee. Anyways here are the two parts you need from the D8:
-->The shocks for you<--
-->The rear tower for you<--
4. 電調和電機,這個我打算換成HOBBYWING 150A 的,電機就要再看看了,看其他的帖子說4000KV上4S會太快.
4000kv is definitely a NO-NO if you want your truck to run well in a track. I would recommend Hobbywing 4274SD 2000kv for 月野倉. I ran Tekin RX8(RX8 is a continuous 210A電調) with T8 2250kv truggy motor and 4S lipo in my RC8 before, and that was wayy too fast for me. Now I run a 1700kv and I love it. Because your truck is really heavy, I would consider the Hobbywing 4274SD 1800kv with conservative gearing just to keep the motor cool. Just remember to get some decent lipos if you are running the Hobbywing 150A or the RX8(RX8 here), because your truck is so heavy the motor will draw more current from your 電調 and your 電調 will pull more amperage from your battery.
But before you buy any mods, drive the truck on the track a few time and see if you actually want to change anything. The reason I think you need those shocks is because I've seen your truck on the track, once, and I notice the suspensions bottom--out really easily. That's why I recommend you to gain some travel for your suspension.
yaksy 长老 Fans 发消息
发表于 12-5-5 21:13:56 |显示全部楼层 来自: 中国湖北武汉
楼主加油!楼主出测评!
cristiano7 RC 新手 发消息
发表于 12-5-6 23:54:40 |显示全部楼层 来自: 中国江苏扬州
漂亮啊~~好车~
wf41019 论坛元老 发消息
发表于 12-5-7 22:24:39 |显示全部楼层 来自: 中国宁夏银川
这个好像没8sc和sc8e性价比高吧
黑色光盘 RC 新手 发消息
发表于 12-5-15 20:57:16 |显示全部楼层 来自: 中国辽宁大连
昨天在淘宝订的阿帕奇C1。等待中。。。。
baishun 长老 Fans 发消息
发表于 12-5-16 19:54:42 |显示全部楼层 来自: 中国重庆
小猫好好玩!!!可爱
stliudong 长老 Fans 发消息
发表于 12-5-24 07:08:06 |显示全部楼层 来自: 中国北京
这个车其实就是D8的架子,FLUX的老版电机,这个车绝对是爽玩车,不用纠结什么可调,足够结实,大F在我手里玩一次坏一次,这车在我手里倒没事,呵呵,楼主放心玩吧,绝对支持6S,换一下电调,电机足够了。
dickyyim03 高级 Fans 发消息
发表于 12-5-26 17:58:34 |显示全部楼层 来自: 中国香港
stliudong 发表于 12-5-24 07:08
这个车其实就是D8的架子,FLUX的老版电机,这个车绝对是爽玩车,不用纠结什么可调,足够结实,大F在我手里玩 ...
正在考慮換那一種電調及電機.
好盈的防水套裝好像不錯.
還是有別的好介紹嗎
a12548382 金牌 Fans 发消息
发表于 12-5-26 21:53:48 |显示全部楼层 来自: 中国河南平顶山
原车电机电调4s跑起来不会上55
