本帖最后由 emacemac 于 12-5-2 16:00 编辑 回复 dickyyim03 的帖子 Too late and too lazy to type Chinese. So here is the list of what I think you should have if you want to optimize your truck for that track with minimal amount of spending: 1. D8 turnbuckles(all of it!) 2. Rear D8 HARA edition shocks plus rear HARA shock tower(you will need to drill a few holes on the tower to mount the body post), 3. Get a more powerful/faster servo. 200oz/inch of torque at least, something like Savox 1256tg will do nicely. Or even better a Hitec 7955tg. 4. That Q-base speed control is just a re-badged Castle Mamba Max Pro. MMP is known for having weak BEC, so get a Novak Glitch Buster(cheap!) or make one yourself(you are cheap!) before it browns out on you at the track(it's annoying). Also get a Castle Link USB Programming kit. It's also cheap and it will give you access to a long list of perimeters to adjust the truck's power system to your liking. 5. If you are using the stock radio system, get something like a Airtronic MT4 or Futaba 4PL or Spektrum DX3c. You won't regret it, they make a world of difference. At most club level those flagship radios are not necessary(4PKS/M11x/DX3R) unless you are desperate to try to look cool. 6. Drive! Drive a lot! Practice make perfect! If you don't want to go door to door at 廣華街 then Amainhobbies and Tower hobbies will be the great. Google them if you want to compare prices with your local stores I am in California so pardon me for my broken English |
回复 emacemac 的帖子 非常用心的教導~小弟受教了,謝謝熱心的回覆! 1. D8 turnbuckles(all of it!) 這個短期內一定會換的! 2. Rear D8 HARA edition shocks plus rear HARA shock tower(you will need to drill a few holes on the tower to mount the body post), 油壓喔~這個好像得複雜呢.還要外孔位上油壓架.我應該做不來.多看文章看看有沒教學! 3. Get a more powerful/faster servo. 200oz/inch of torque at least, something like Savox 1256tg will do nicely. Or even better a Hitec 7955tg. Savox這品牌的saver確實不錯,有在用1251mg在我的T3上,對這品牌很有信心. 4. That Q-base speed control is just a re-badged Castle Mamba Max Pro. MMP is known for having weak BEC, so get a Novak Glitch Buster(cheap!) or make one yourself(you are cheap!) before it browns out on you at the track(it's annoying). Also get a Castle Link USB Programming kit. It's also cheap and it will give you access to a long list of perimeters to adjust the truck's power system to your liking. 電調和電機,這個我打算換成HOBBYWING 150A 的,電機就要再看看了,看其他的帖子說4000KV上4S會太快. 5. If you are using the stock radio system, get something like a Airtronic MT4 or Futaba 4PL or Spektrum DX3c. You won't regret it, they make a world of difference. At most club level those flagship radios are not necessary(4PKS/M11x/DX3R) unless you are desperate to try to look cool. 這個沒問題,正在使用4PL,多買一個接收就可以了 6. Drive! Drive a lot! Practice make perfect! 一定會多練習!! |
