刚从Corona官网找了相应的PDF资料,里面说的居然和随产品附的说明书说法不太一样。具体如下。 Receiver and Transmitter Setup Instructions By following these steps you will ensure your transmitter and receiver are properly setup and ready to fly. 1. Turn the transmitter on and adjust your transmitter to PPM mode (not PCM), and then turn the transmitter off. 2. Press and hold down the programming button on the transmitting module, then turn the transmitter on. The LED on the module will flash between red and yellow indicating the transmitter is ready to bind with a receiver. 3. Press and hold down the button on the receiver and connect the receiver to the battery. The LED on the receiver will flash red twice indicating the receiver is in binding mode. Within a few seconds the receiver LED will flash rapidly for a moment indicating that it has successfully bound to the transmitter module and both are now communicating on the same channels. Turn off the transmitter and receiver now. Note: If the receiver did not flash rapidly then binding was not successful. Check that the transmitter module is flashing Red/Green, then restart the receiver binding by removing the receiver battery for a few seconds and then reapplying with the button pressed on it again. Binding is best done without any servos connected but this is normally not necessary. 4. Check the normal system operation. Turn the transmitter on, when the module LED is yellow then connect the receiver to the battery. The red LED on the receiver will be fully ON, indicating the receiver is operating properly. Receiver LED will be OFF when there is no signal. Note: The transmitter MUST be turned on BEFORE the receiver is connected to the battery, or else the receiver will not initialize. This is also a best practice for RC model safety. After following these steps to program your transmitter and receiver, both modules will continue to operate together each time you use the modules without further binding. If there is a need to reprogram your modules (adding another receiver) please follow these steps above again. |
tonyshan007 我挺你,对于国产我也是有狠深的感情的 对 以前的是不好 但是新推出的有个改进这是我们想看到的 国产 有些地方是不尽人意 对于那些习惯了高级控的米人,就是垃圾 认为 4VF也比天9 通道多 现在的经济危机下 都想出口 但是又出不去 只能拉动内需 来促进人民的生活水平 国内厂家推去新的产品 相对于以前的产品有狠大的改观 这就是正真的争气了 以价格来打造市场,卖的多了 才有资金去研发 测试 没米 你能干什么? 吃饭都是问题 你还能玩模型~!! 别以为外国什么都好去听听“许四多” 让你明白什么是中国人~!!! |
