遥控大猫 超级元老 发消息
发表于 07-8-7 19:33:20 |显示全部楼层 来自: 中国北京
回复 #20 禮銚 的帖子
买一台928啦
禮銚 论坛元老 发消息
发表于 07-8-7 19:39:55 |显示全部楼层 来自: 中国澳门
The new 28XZ Truggy Engine – perfectly balanced power for today’s truggies! With input from top truggy drivers, O.S. has developed the ideal engine for these hybrid hot rods! The 28XZ produces more low-end torque, providing the rpm/torque balance that heavier truggies require. The result is power that’s incredibly smooth! And the 28XZ comes with all the components serious racers need for fine-tuning to meet any conditions: Two carb inserts – a 9 mm blue for higher rpm applications and larger tracks and an 8 mm red for smaller tracks that restrict air intake, an extra copper head shim for more head raising/lowering options and a piston sleeve that boasts 6 ports for significantly increased power.
• The larger head aids in cooling and is a 2-piece construction with inner head button.
• A sealed front bearing and high-performance inner bearing are part of the new crankcase design.
• The high-performance con rod features oiled bushings. • Three needles enhance fine-tuning on the 21J slide-valve carb.
• Comes with a high-performance P3 hot turbo plug
• The Mark Pavidas Edition Tuned Pipe is the perfect accessory for the 28XZ; flywheel sets are required (sold separately) for certain truggy models.
Specs: • Displacement: 0.284 cu in (4.65 cc) • Bore: 0.728 in (18.5 mm) • Stroke: 0.681 in (17.3 mm) • Practical rpm: 4000-38,000 • Power Output: 3.31 hp @ 32,000 rpm • Weight: 13.1 oz (375 g)
OSMG2074 28XZ Truggy
发表于 07-8-7 20:05:06 |显示全部楼层 来自: 中国广东广州
hzf9911 超级元老 发消息
发表于 07-8-7 20:36:00 |显示全部楼层 来自: 中国广东深圳
无卡车比赛~~~~
禮銚 论坛元老 发消息
发表于 07-8-7 20:41:30 |显示全部楼层 来自: 中国澳门
原帖由 Jason_Jo 于 2007-8-7 07:33 PM 发表
买一台928啦
928??什麼東西??請提供一點資料…猫猫
发表于 07-8-7 20:47:10 |显示全部楼层 来自: 中国广东佛山
发表于 07-8-7 20:47:58 |显示全部楼层 来自: 中国广东佛山
禮銚 论坛元老 发消息
发表于 07-8-7 20:56:49 |显示全部楼层 来自: 中国澳门
:em04: :em04: :em04:
QFeng918 超级元老 发消息
发表于 07-8-7 21:15:56 |显示全部楼层 来自: 中国广东广州
呵呵.我也是CRT PRO..........
QFeng918 超级元老 发消息
发表于 07-8-7 21:17:03 |显示全部楼层 来自: 中国广东广州
原帖由 dy 于 2007-8-7 08:05 PM 发表
斗车我肯定上21的啦.....是否有节目啊?虽然我无卡车,但可以做助手咖.....
如果老板不嫌弃的话.可以用我台已经.封尘以久的CRT出赛喔.
