本帖最后由 Traxxas 于 17-7-8 15:02 编辑 TRAXXAS技术贴视频第十一期---TRX-4如何设置T-LOCK舵机 视频原创发布者 BY TRAXXAS 翻译者 BY TRAXXAS中国总代理电波模型 因涉及到模型专业术语,如若翻译有误,欢迎指正! 以英文原档为准,请参考: TRAXXAS – TRX4 HOW TO SET THE T-LOCK SERVOS The TRX 4 T-LOCK differential control servos are installed and preset at the factory. If you need to remove the servos or the servo horns for maintenance or cleaning, carefully note that the orientation when you reinstall them, to make sure the T-LOCK system operates properly. Power on the transmitter and speed control, and plug the servos into their correct positions on the receiver. The front T-LOCK servo plugs into the Channel 4 slot and the rear T-LOCK servo plugs into Channel 5. Operate the T-LOCK switch on the transmitter to test both servos. Then move the switch to the open position for unlocked front and rear deck. T-LOCK Switch: T-LOCK Forward Position – Both Differentials Locked Middle Position – Front Differential Locked Rear Position – Both Differentials Open For the front T-LOCK servo, install the spring-loaded servo horn so the spring slot is perpendicular to the linkage. For the rear key lock servo, install the servo horn so the spring slot is parallel to the linkage. Carefully secure servo horn when installing hardware, and avoid over-tightening screws. Move the T-LOCK switch to the middle position, confirm that the service output shaft turns counterclockwise to rotate the servo horn as shown, move the switch to the front position to lock the rear differential. Now the servos are properly oriented for the T-LOCK system to function. See the manual for more information about the T-LOCK system in all features for the TRX4. 请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新! 如果您想了解更多关于我们品牌的资讯, 请咨询电波模型淘宝店旺旺客服: http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE 微信扫一扫,可得知最新资讯! 或联系我们 QQ :2713236907/270570161 手机:13790546054 王小姐 |
