TeamPowers M-Radon 微型有感無刷電變馬達組 適用車種 1/27 Mini-Z . AMZ.BZ.GLA 1/10 摩托車 馬達規格 7200KV .8400KV M-Radon Speed Control: Features: . Mainly design to work with 1:27 miniz car, 1:10 motorcycle or any other model that can fit into it . Inheritied the hardware and software design from 1:10 Radon V2 series speed control . With some new software function such as Drive Frequency, Brake Frequncy, RPM lock(Power band control) . Compatible with Sensored/Sensorless Brushless Motors . Data Analysis Capability(RPM, Low voltage and ESC temperature) with the use of LCD card . HotWire PC Interface for Advanced Programming and Updating . Easily Programming through the LED card(included in the package) . Built-in one touch On/Off switch with LED . Bulit-in Low voltage cut-off, Overheat protection and signal loss protection Specification: Battery Input Voltage: 2S lipo BEC: 6V/1.5A 1/27 motor Limit: 10000kv or bleow Max Ampere draw: ~20A per phase Size: ~21x24x10mm Weight: ~10g(without any wire installed) MBX Brushless Motor Specification: - Sensor type - Motor Dimension (Diameter x Length): 16mm x 27mm - Shaft Diameter: 2mm - Weight: 18.5g - Available KV: 7200KV, 8400KV |
