Jaycee 高级 Fans 发消息
发表于 14-8-2 15:01:29 |显示全部楼层 来自: 美国
上图
新鲜无比的小E一辆。
Jaycee 高级 Fans 发消息
发表于 14-8-2 15:12:02 |显示全部楼层 来自: 美国
发全部组件名录及价格以供参考。
Pro-Line 1071-13 Dirt Hawg Tires Mounted Titus Wheels (4) 1/16 E-Revo VXL                             $59.99
Traxxas 7118X Pust rods, Aluminum        $15.99
Traxxas CVD        $44.99
Traxxas 7014 1/16 Diff Kit/Center VXL TRA7014        $13.49
Traxxas 1/16 Steel Center Driveshafts        $24.45
Traxxas 1/16 Mini Revo Slash Multi Rate Rocker Arm (item# VXS27FX)                                         $14.33
Traxxas Mini 1/16 Revo, Slash Multi Rate Rocker Arm (item# VXS27RX)                                  $13.89
Traxxas Mini 1/16 Revo Slash Blue Aluminum Wheel Hex Mounts (item# TOYZ 203 Blue)    $9.68
RPM Traxxas Mini 1/16 Revo Black Rear Arm Set (item# RPM 80602)                                  $10.89
Traxxas Mini 1/16 Revo Slash Silver Aluminum Motor Heat Sink (item# TOYZ 56 Silver)          $7.19
Traxxas Mini 1/16 Revo, Slash Red Knuckle Axle Hub Carriers (item# RPM 73169)                  $19.90
Team Associated 18T Differential Shim Set, .324x.409x.005 (4) (item# ASC21141)                  $2.09
Traxxas 1/16 Mini Revo, Slash Steering Servo Gear Set (item# TRA2082)                                  $3.29
Traxxas 1/16 Mini E-Revo, Slash Steel Machined Hollow Balls (22) (item# TRA7028X)                  $5.89
Traxxas Mini 1/16 Revo Slash Steering Ball Bearing Set (item# TOYZ 202)                           $2.98
Traxxas Mini 1/16 Revo, Slash Waterproof Steering Servo (item# TRA2080)                          $21.95
Traxxas 1/16 Mini Revo, Slash GTR Shock Damper Set (item# TRA7061X)                          $36.98
Traxxas 1/16 Mini Revo Red Tube Toe Links (item# TRA7138X)                                          $21.49
Traxxas Differential Oil 30K weight (item# TRA5136)        $6.28
Traxxas 1/16 Mini Revo GTR Shock Spring 2.22 Rate (item# TRA7148)                                  $3.19
Traxxas Mini 1/16 Revo, Slash, Summit Car Silver Aluminum Shock Bottom Cap Retainer    $3.78
Blue Spring Antenna Tube (item# ANTS06)        $4.89
Traxxas Mini 1/16 Revo Front & Rear Bumpers (item# TBR 62034)                                          $26.94
CASTLE CREATIONS V3 MAMBA MAX PRO SPEED CONTROL 5700KV 4 POLE MOTOR          $159.95
Hobbywing Xerun V10 sensored brushless 6.5T Motor                                                          $53.5
Turnigy Accucel-6 Accucell LiPo Charger        $39.69
MOTOR PLATE * Titan 550        $10.00
2200mAh 2s 40c Lipo        $56,85
        Total:                          $689.77
bendaye  若真是6S估计不止是蛋疼了,连鸡脖也得跟着抽了  发表于 14-8-13 18:44
苦命娃  唯一蛋疼处是 最高 4S !要是能 6S 耍就完美了!!!!  发表于 14-8-3 18:42
苦命娃  卡斯特MMP电调的亮点!据说兼容各种10车8车电机,有刷,无刷,有感,无感电机!还TM是温感风扇!!  发表于 14-8-3 18:41
Jaycee 高级 Fans 发消息
发表于 14-8-2 15:52:29 |显示全部楼层 来自: 美国
补充感想:
1,小e真TM不结实,说实话本来压根没打算所任何额外投资的,就是想买个小车填补一下当初玩儿四驱车的回忆,结果第一次玩儿就断了前A臂,磨了舵机齿。刚修好又把前车壳支架搞断了,索性就放开升级吧!
2,原厂的Velineon 3m ESC实在不够力,但好盈xerun V3.1又太费电,所以就买了Mamba max pro+4 poles 5700kv套装,结果发现无感实在不顺滑,于是又换了好盈V10,这下踏实了,还算顺滑的操控加上足够的爆发力,而且单节2200mah 2S居然可以玩儿20分钟,很不错了。
3,这车本来避震就太软,换装1/10动力后更重了,先后试过原厂1.92和2.22系数的弹簧都不够满意,最后用了summit vxl的2.77弹簧和80k的油,舒服多了。
4,全车金属传动后加装中差速后比原厂要感觉好很多,只是现在还在摸索这车的差速油配置,我现在用的是30:50:30,过阵子换成30:100:50试试。
5,Tra2080的舵机齿轮真垃圾,不过先双舵机跑着。买了个Hitec 5085,不过转臂还没到,到时候就单舵机了。
6,proline的轮胎很扎实,很讨喜的质感,不过因为比原厂重了一倍,齿轮比太夸张的话电机很热,不过好处是压车了,稳了很多。
7,T—Bone的前后防撞实在值得推荐,还有全底盘护甲可以选择。
暂时先这么多。
小毛牛 超级元老 发消息
发表于 14-8-2 18:41:45 |显示全部楼层 来自: 中国江苏南京
那升级后怎么样  结实啦?????
alienware0312 中级 Fans 发消息
发表于 14-8-2 23:15:14 |显示全部楼层 来自: 中国上海
Jaycee 发表于 14-8-2 15:52
补充感想:
1,小e真TM不结实,说实话本来压根没打算所任何额外投资的,就是想买个小车填补一下当初玩儿四 ...
t-bone的前后防撞在哪里有卖的啊
摆事可乐 论坛元老 发消息
发表于 14-8-3 00:15:43 |显示全部楼层 来自: 中国河北邢台
这轮胎不错啊  不知道我的 LC 小越野能不能用呢
摆事可乐  有俩.........  发表于 14-8-3 19:42
小毛牛  你不是 要出吗  发表于 14-8-3 10:14
Jaycee 高级 Fans 发消息
发表于 14-8-3 02:47:45 |显示全部楼层 来自: 美国
小毛牛 发表于 14-8-2 18:41
那升级后怎么样  结实啦?????
起码看起来是结实了
Jaycee 高级 Fans 发消息
发表于 14-8-3 02:49:01 |显示全部楼层 来自: 美国
zhufengfly 发表于 14-8-2 22:55
买车还是尽量买主流车!
Merv在美国还算主流,玩儿的人不少
Jaycee 高级 Fans 发消息
发表于 14-8-3 02:49:48 |显示全部楼层 来自: 美国
alienware0312 发表于 14-8-2 23:15
t-bone的前后防撞在哪里有卖的啊
Toyz
http://www.thetoyz.com/
Jaycee 高级 Fans 发消息
发表于 14-8-3 02:50:49 |显示全部楼层 来自: 美国
12mm的连接,不知道能不能用。轮子是好轮子
