[产品信息] EVO2-483-2 EVO2 Red Steel Universal Shaft Joint
查看: 1390|回复: 0| [复制链接]
发表于 14-2-22 09:24:56 |显示全部楼层 来自: 中国香港
H-K1 Optional Parts
Special Features :
1. Both hub & shaft joint made by red steel with harden treatment to give the maximum hardness & stiffness
2. With grinding process for the hub to increase the accuracy of bearing fitting
3. Suitable for all H-K1 Series
http://kmrcshop.com/products/EVO ... al-Shaft-Joint.html
http://www.km-rc.com/
