[产品信息] EVO2-483-1 Red Steel Universal Shaft Hub
查看: 1425|回复: 0| [复制链接]
发表于 14-2-22 09:22:40 |显示全部楼层 来自: 中国香港
H-K1 Optional Parts
Special Features :
1. Super light weight , high efficiency on transmission
2. Red steel head with grinding process to in crease the accuracy of bearing fitting.
3. Shaft is using 7075-T6 with hard coating
Special Features :
1. Both hub & shaft joint made by red steel with harden treatment to give the maximum hardness & stiffness
2. With grinding process for the hub to increase the accuracy of bearing fitting
3. Suitable for all H-K1 Series
http://kmrcshop.com/products/EVO ... rsal-Shaft-Hub.html
http://www.km-rc.com/
