Yeahracing 高级 Fans 发消息
发表于 13-11-15 17:23:40 |显示全部楼层
Yeah Racing Gear Differential Leak Tester Mount for RC Car Tamiya 416 417 417X 417V5, Sakura Zero XI , Yokomo BD5 BD7, Team Associated TC6 TC6.1 Aluminum Orange #YT-0120OR
Description:
Get messy when oiling the differentail gear? Never again with this gear differential tool.
This gear differential tool is designed to hold the differential gear in place. It is a perfect tool for oiling, setting up, regearing & rebuilding differential gears. In the bottom there is a tray to hold the gearing oil, avoiding it to spill over in the table/ rc pit map.
Other usage:
1. Hold the RC motor (for motor maintenance, perform differential test)
2. Hold the RC car
and more...
Feature:
For: Gear Differential, Motor, Mini Z Car Setting
Material: Aluminum
Color: Orange
Specification:
Length: 45mm
Width: 29.5mm
Height: 25.3mm
Include:
Gear Differential Leak Tester Mount Aluminum Orange (1pc)
密切留意YEAH RACING专区,为你提供最新资讯!
更多YEAH RACING产品,请关注电波淘宝:http://item.taobao.com/item.htm?spm=0.0.0.0.zMbZfH&id=36070009738
