Adjustable Timing Compatible with any Sensored/ Sensorless ESC Dual-Plug Sensor Wire Harness for use with all Sensored and Sensorless Systems CNC Machined Billet T6 Aluminum Heatsink Can High Purity Copper Windings Maximizes Conductivity Anodized EndBell Plate Maximizes Corrosion and Wear Resistance High RPM Output High Power Solder Tabs A.B.E.C. 5 Oversized Precision Bearings Removable/Replaceable Rotor Powerful Sintered Neodymium Magnet Precision Engineered for Maximum Energy Conversion 6061 T6 Aluminum Can Diameter 36mm x Length 66mm Weight 8.30 oz / 234 grams Shaft 15.3mm x 5mm Sensored 3mm and 4mm Mounting Holes
