HPI版的Slash!
查看: 11476|回复: 36| [复制链接]
发表于 09-7-31 20:19:28 |显示全部楼层 来自: 中国北京
HPI Racing Blitz
RTR, 1:10 Scale, Electric, 2WD Short-Course Truck
#103171
RTR Blitz Short-Course Truck
w/ Maxxis ATTK-10 Body
发表于 09-7-31 20:22:00 |显示全部楼层 来自: 中国北京
Chassis
Proven tough chassis based on the E-Firestorm platform
Proven HPI durability throughout
The HPI Blitz uses nothing but the finest grade, high-impact nylon plastic on the most critical areas of the truck - from the bumpers to the super beefy arms and everything in between. HPI's industry known strength and durability makes the Blitz friendly for all - be it an R/C newcomer, or the skilled competitor.
Lengthened chassis
The Blitz features an all-new main chassis based on the E-Firestorm - lengthened to deliver the most stable feel a short-course truck can offer.
Adjustability
The Blitz is fully tunable - from multiple shock angles, camber and toe, to anti-squat and more
High Performance Shocks
The threaded shock bodies feature super smooth shock action , as well as quick, on-the-fly adjustability.
Baja 5T Inspiration
The unique and proven pivoting skid-plates have been adapted from the unmatched Baja 5T platform, which are able to truly absorb impacts.
Maximum Rear Traction
Factory installed quick-change 3-degree rear toe block provides you with plenty of traction, and making changes is easy.
Gallery
All metal gear transmission
A bulletproof, brushless ready, full-metal gear transmision comes stock in the truck, and is made to handle all the power you can throw at it. Silicone oil is also pre-filed in the diff for an enjoyable, easy-to-drive experience.
Firebolt 15T Motor
The blistering Firebolt 15T Motor provides plenty of power - from speed runs to competing at your local track.
Full ball bearings
A complete set of rubber sealed ball bearings are included for super smooth drivetrain operation.
12mm Hex Hubs
12mm Hexes will keep your wheels secure under extreme power, and will keep them from stripping out. 12mm Hex Hubs are the short-course industry standard allowing you to customize your truck with a wide variety of aftermarket parts.
Captured Hinge Pins
E-Clip-less captured hinge pins make maintenance quick and hassle free, and also keep the suspension extremely smooth and snug.
Secure battery mount
A simple flip of the rear battery mount will allow you to secure the NiMH/Ni-CD or Li-Po battery pack of your choice with an easy to use thumbscrew hold doown strap.
发表于 09-7-31 20:22:14 |显示全部楼层 来自: 中国北京
TF-1 Transmitter
The reliable and sturdy HPI TF-1 radio controls the Blitz short-course truck. Trugger-style throttle and brake controls provide you with finger-sensitive action when accelerating and stopping! It features interchangeable frequency crystals, servo reverse switches, a retractable antenna and simple battery replacement.
Permalink: http://www.hpiracing.com/products/en/103171/
发表于 09-7-31 20:23:24 |显示全部楼层 来自: 中国广东阳江
cqhdd 论坛元老 发消息
发表于 09-7-31 20:23:44 |显示全部楼层 来自: 中国重庆
看起来不错哦
jims4236 金牌 Fans 发消息
发表于 09-7-31 20:24:16 |显示全部楼层 来自: 中国北京
先沙发再看。。。。
zdc840945566 论坛元老 发消息
发表于 09-7-31 20:41:28 |显示全部楼层 来自: 中国上海
感觉A臂没slash结实
上山植树 超级元老 发消息
发表于 09-7-31 20:58:05 |显示全部楼层 来自: 中国北京
为什么不是4WD呢?
自由大帝 超级元老 发消息
发表于 09-7-31 21:01:20 |显示全部楼层 来自: 澳大利亚
感觉A臂没slash结实
zdc840945566 发表于 09-7-31 19:41
去玩多几台车再来发表~~
发表于 09-7-31 21:01:43 |显示全部楼层 来自: 澳大利亚
