New JR XS3 Pro
查看: 2377|回复: 0| [复制链接]
发表于 04-7-25 00:13:00 |显示全部楼层 来自: 中国广东广州
JR’s new XS3 Pro is an incredible combination of synthesized signal simplicity and an outstanding list of features. Using synthesized signal processing, the XS3 Pro allows racers to dispense with crystals and adjust their system’s signal to whatever frequency the track environment requires. No longer will racers have to sit out a heat because someone else shares the same channel. They can simply tune in an unused frequency and race on.
Along with this sophisticated synthesized signal technology, the XS3 Pro features all the outstanding programming functions that users of the XS3 have come to know and love. This includes multipoint throttle curves, dual-rate steering, exponential and many other tuning options. The XS3 Pro also retains the separate button for use with nitro trucks that have reversible transmissions, such as the Traxxas T-Maxx.
The XS3 Pro, however, does differ from its predecessor in a few notable areas. The most noticeable of these is the silver metallic finish that really stands out at the track. JR has also replaced the stock RS300 synthesized receiver with the newly designed RS310. The RS310 possesses all the same precision as the RS300, only it’s smaller and much easier to mount. There are even a few ergonomic touches that make the XS3 Pro more comfortable to use, like an adjustable throttle trigger, grip pad and momo-style steering wheel.
Each XS3 Pro system includes one Z590M metal gear servo and one Z270 servo and is available in 75MHz
