全新的红色金属高压舵机,A-40CHV、A-50CHV适用于航模,30~200cc电动、油动和涡喷飞机; * 全CNC金属红色外壳 * 7075+416进口钢齿 * 日本进口电位器 * 高压空芯杯马达,兼容6.0-8.4V电压 * 新版PGC可编程系列,配合脱机编程卡可对舵机进行参数设定。 A-40CHV 参数: Torque(6.0V): 25.0 kg-cm ( 347.2 oz/in) Torque(7.4V): 35.0 kg-cm ( 486.1 oz/in) Torque(8.4V): 40.0 kg-cm ( 555.5 oz/in) Speed: 0.14 sec (6.0V)│0.12 sec (7.4V)│0.10 sec (8.4V) Operating Voltage:6.0 ~ 8.4 DC Volts Weight: 80 g (2.82 oz) Bearing Type:Ball Bearing x 2 Motor Type:Coreless Motor Gear Type:Steel & Aluminum Operating Temperature:-20℃~60℃ Working frequence:1520μs / 333hz Size:40.7 x 20.5 x 38.7 mm ( 1.60 x 0.81 x 1.52 in) A-50CHV 参数: Torque(6.0V): 35.0 kg-cm ( 486.1 oz/in) Torque(7.4V): 45.0 kg-cm ( 625.0 oz/in) Torque(8.4V): 50.0 kg-cm ( 694.4 oz/in) Speed: 0.19 sec (6.0V)│0.17 sec (7.4V)│0.16 sec (8.4V) Operating Voltage:6.0 ~ 8.4V DC Volts Weight: 80 g (2.82 oz) Bearing Type:Ball Bearing x 2 Motor Type:Coreless Motor Gear Type:Steel & Aluminum Operating Temperature:-20℃~60℃ Working frequence:1520μs / 333hz Size:40.7 x 20.5 x 38.7 mm ( 1.60 x 0.81 x 1.52 in) |
