[遥控设备] Spektrum DX3遥控器如何调节舵量
查看: 5607|回复: 17| [复制链接]
小贝12345 RC 新手 发消息
发表于 21-4-27 17:50:51 |显示全部楼层 来自: 中国浙江
有没有大神知道Spektrum DX3遥控器如何关掉AVC,调节舵量
小贝12345 RC 新手 发消息
发表于 21-4-27 17:52:54 |显示全部楼层 来自: 中国浙江
wlz008 超级 Fans 发消息
发表于 21-4-27 19:12:34 |显示全部楼层 来自: 中国北京
AVC那个旋钮拧到最小就关闭了,舵量得看看说明书了
wlz008 超级 Fans 发消息
发表于 21-4-27 19:14:36 |显示全部楼层 来自: 中国北京
End Point Adjustment Mode
The default end point value is 100% for both steering and
throttle/brake. The maximum end point value is 150% with
adjustment.
To adjust the endpoints of the steering and throttle/brake:
1. Power the transmitter on while holding the steering
wheel full right and holding the trigger at full brake. The
power LED flashes blue to indicate the transmitter is in
end point adjustment mode.
Steering:
2. Turn and hold the steering wheel full left. Turn the
steering rate knob to set desired end point.
3. Release the steering wheel and reset the steering rate
knob to full.
4. Turn and hold the steering wheel full right and turn
5. Release the steering wheel.
If you are adjusting the throttle/brake end points, continue to
the next section. If you are not adjusting the throttle/brake
end points, power off the radio now to save the settings. Set
the rate and brake rate knobs back to the desired positions
before operating the vehicle.
Throttle/Brake:
6. Set the throttle limit (TH LIMIT) switch to 100.
7. Hold the trigger at full throttle.
8. Turn the brake rate knob to set desired end point.
9. Release trigger and reset brake rate knob to full.
10. Hold the trigger at full brake.
11. Turn the brake rate knob to set the desired end point.
12. Release the trigger.
13. Power off to finish.
14. Set the steering rate and brake rate knobs back to the
desired positions before operating vehicle.
wlz008 超级 Fans 发消息
发表于 21-4-27 19:15:16 |显示全部楼层 来自: 中国北京
adjustment.
Steering:
knob to full.
Throttle/Brake:
小贝12345 RC 新手 发消息
发表于 21-4-28 12:30:04 来自手机 |显示全部楼层 来自: 中国浙江金华
adjustment.
Steering:
knob to full.
Throttle/Brake:
看不懂啊
wlz008 超级 Fans 发消息
发表于 21-4-28 13:09:33 来自手机 |显示全部楼层 来自: 中国北京
找谷歌翻译,慢慢对照着来吧。
wlz008 超级 Fans 发消息
发表于 21-4-28 13:10:38 来自手机 |显示全部楼层 来自: 中国北京
右满舵和完全刹车的同时,打开遥控。
wlz008 超级 Fans 发消息
发表于 21-4-28 13:11:15 来自手机 |显示全部楼层 来自: 中国北京
接收机会闪耀蓝色的灯
wlz008 超级 Fans 发消息
发表于 21-4-28 13:12:25 来自手机 |显示全部楼层 来自: 中国北京
方向打到左满舵并维持,然后用转向微调旋钮调整最大舵机量。
