本帖最后由 Traxxas 于 17-6-16 19:46 编辑 TRAXXAS技术贴视频第七期---如何让车子翻转 视频原创发布者BY TRAXXAS 翻译者BY TRAXXAS中国总代理电波模型 因涉及到模型专业术语,如若翻译有误,欢迎指正! 以英文原档为准,请参考: TRAXXAS – How To Perform Flips And Tricks You may have seen TRAXXAS figure freestyle demonstrations at Motorsports events in the past. If not check the event calendar on TRAXXAS.com to see a list of upcoming events. Just like freestyle motocross four-wheel, drive TRAXXAS RC vehicle are capable of performing incredible front flips back flips and more. Using the rotational master the tires and wheels to affect the vehicle angular momentum or rotation . Lets take a look at the equipment we will be using and how to perform these flips and tricks To achieve big jumps and maintain control in the air, we use models with four-wheel drive and brushless power. Lipo batteries are ideal for performing big tricks . A 2 cell lipo for the slash 4x4 dual 2 cells the E-Revo brushless and dual 4 cells for the 8s X-MAXX How do these trucks rotate in the air? After the model jumps apply throttle and the vehicle will rotate backwards. When reverse throttle is applied, the model rotates forward . Even if you are not performing a flip or trick, throttle can be used to keep the model level in the air and control the landing. Consider any variables when performing these tricks such as wind speed and direction, surface and environment and the size and angle of the jump. Always take precautions to keep yourself and others at a save distance from the vehicle. We will start with a backflip using the E-Revo brushless position. Line up the jump and hit it straight on,full throttle is not necessary, to get plenty of air and let off some as you hit the jump as your vehicle launches keep it straight and apply the throttle . Don’t apply too much or the model will over rotate. Now let’s see how to perform a front flip with the 8S XMAXX. Hit the jump straight on and after the model launches hit the brakes and quickly apply reverse throttle . With some practice, you will be able to determine when to hit reverse and how to control the throttle for a smooth landing . Here is a fun trick for the Slash 4x4, we like to call the switch flip. This one is a little more advanced but it’s sure to impress a crowd. Approach the jump in reverse. It is especially important to hit the jump straight in reverse fir this truck. Just after the model launches, turn the wheels to either side and immediate taps brakes if needed, apply forward throttles to fully rotate the vehicle. When time just right, the model will perform a twist and flips then come down for a purpose landing. When time just right, the model will perform a twist and flips then come down for a purpose landing. 请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新! 如果您想了解更多关于我们品牌的资讯, 请咨询电波模型淘宝店旺旺客服: http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE 微信扫一扫,可得知最新资讯! 或联系我们 QQ :2713236907/270570161 手机:13712111381 王小姐 |
