发表于 17-4-27 19:23:59 |显示全部楼层
TRAXXAS技术贴视频第三期---如何更换转向舵机
视频原创发布者BY TRAXXAS
翻译者BY TRAXXAS中国总代理电波模型
以下是中国TRAXXAS总代理电波模型帮做出的翻译视频,
因涉及到模型专业术语,如若翻译有误,欢迎指正!
以英文原档为准,请参考:
LaTrax - How to Replace a Steering Servo
     If your LaTrax vehicle is having trouble steering or has lot steering completely, you may need to  replace the steering servo.
     Get a replacement servo for your vehicle and followed these steps.
     First, remove the body and the battery from the vehicle.
     Open the receiver box and disconnect the servo connector from the channel one slot.
     Remove the two screws on the underside of the chassis to release the servo.
     Carefully remove the servo from the chassis and unscrew the servo horn from the servo.
     Remove them out from the old servo and place it on the new servo.
     Plug the connector back into the channel one slot in the receiver and close the receiver box.
     Power on the transmitter and vehicle, and use the dial on the transmitter to center the steering shrimp.
     With the steering trim centered, orient the servo horn so that it points up.
     Hold the servo horn firmly as you reattach it to the servo.
     Reinstall the servo.
     With the servo and mount lined up with the holes in the bottom of the chassis, reinstall the two screws you removed earlier.
请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新!
如果您想了解更多关于我们品牌的资讯,
请咨询电波模型淘宝店旺旺客服:
http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE
微信扫一扫,可得知最新资讯!
或联系我们
QQ  :2713236907/270570161
手机:13712111381 王小姐
