Medal Pro举办一项比赛,就是参赛者为Medal Pro设计轮胎,胜利者将获得100套轮胎+轮圈!具体参赛要求和规格: DESIGN IT YOURSELF ! Participate in the International Medial Pro Tyre Design Challenge! The winning entry will first of all receive one racing season’s worth of Medial Pro tyres (100 pairs of tyres glued on rims!!!) and the winning tyre design will be named after the winner! Medial Pro will be judging the entry in the following categories - Design, - Creativity, - Innovation, - Inventiveness, - Performance The tyre should be designed technically, have a maximum diameter of 120mm (4,72 in) , and be fitted on a rim of 42 mm (1,65 in) width and 80 mm (3,15 in) diameter. In order to participate download the PDF file “Medial Pro, Design it yourself” and design your tyre using it. You can also download the sample file of the Adheris II to help you in your design! Click Here Submit your entry by sending back the PDF of your design at yourtyre@medialpro.com, along with a reference letter explaining your design choices. The competition is open from the 26th of March to the 26th of April 2007. On your mouse, get set, go!challenge regulations |
