原帖由 马达王 于 2006-12-1 01:25 PM 发表 Developed functions of CTX-D2 1. 6 single cells can be discharged. 2. Much more accurate discharging rate and voltage reading. 3. A heat sink is attached to resistors for stability. 4. High RPM dual ball bearing fans for cool operation. 5. Perfect protection system against reverse polarity. 6. 5 polarity guide posts to ensure battery pack is inserted correctly. 7. Provides perfect communications with new PC interface. Specifications Dimensions 196x104x62mm Weight 665g No. of cells 1~6 Discharge current 5A / 30A pulse Cut-off voltage 0.0(dead short)~1.20V(adjustable) Input Voltage 10.0~16.0V Discharging Capability 0~9990mAh(adjustable) Discharging Modes Linear 5A, Dead short, Pulse 30A Keys 4 Cooling IC controlled dual ball bearing fan x 2 IMPORTANT INFORMATION-PLEASE READ CAREFULLY BEFORE USE 1.Always ensure the CTX-D is connected to a suitable 12V power supplyand the power is ON before placing any batteries in the tray. 2.Always ensure you place your batteries correctly in the tray-thebattery bar location on the battery pack MUST match with the batterybar diagram on the CTX-D. 3.Always ensure the polarity of your batteries match with the '+' symbol on the CTX-D. For further information, please refer to Page 2 of the CTX-D Instruciton manual. The CTX-Discharger and Personal Matcher(referred to as CTX-D)is a stateof the art microprocessor based discharger system for Sub-C sizerechargeable batteries for R/C use. With CTX technology developed byour team of R&D, factory team drivers and world champion AtsushiHara, Marc Rheinard and Surikarn Chaidajsuriya. Muchmore introduces thenext generation of discharger for serious R/C drivers. The CTX-D islinear or pulse type discharger and can discharge 1, 3, 4, 6cells or 3,4, 6cell packs. - White back lit LCD with 16x2 characters - IC controlled cooling fans - Latest data memories - External port for communications with computer Pulse discharge is new discharging method which is able to check yourbatteries runtime and Internal Resistance at high discharging rate 30Awithout creating overheat. 30A Pulse discharged runtime is shorter than30A linear. Therefore, it is much closer to the Modified race'sdischarging rate. You can select your best batteries before race attable benchmarks. CTX-D measures IR during Pulse discharge at 2minutes after actual discharged. Lower number of IR means it has more punch. According to out test, new batteries of GP3700 (race level) show Runtime 350~380sec and IR 7~11 on the CTX-D. 自己看就是了,可以放1-6颗独立的电池或者电池组,不知道算不算是你说的平衡放电 |
