XRAY NT18T 详细情况
查看: 3938|回复: 12| [复制链接]
dairy 金牌 Fans 发消息
发表于 06-2-9 01:57:32 |显示全部楼层 来自: 中国广东广州
Main Features
* 1/18 scale, 4WD shaft-drive
* powerful 0.8cc nitro engine uses standard RC nitro fuel
* accepts standard electronics
* super fast (50+ km/h)
* easy to handle in any conditions
dairy 金牌 Fans 发消息
发表于 06-2-9 01:57:55 |显示全部楼层 来自: 中国广东广州
dairy 金牌 Fans 发消息
发表于 06-2-9 01:58:19 |显示全部楼层 来自: 中国广东广州
Main Features
dairy 金牌 Fans 发消息
发表于 06-2-9 01:58:41 |显示全部楼层 来自: 中国广东广州
Chassis
* Swiss T6 7075 CNC-machined chassis
* 1-piece molded radio plate
* top deck for maximum stability
* central, ball-bearing supported steering system
* servo saver included
dairy 金牌 Fans 发消息
发表于 06-2-9 01:59:21 |显示全部楼层 来自: 中国广东广州
Drivetrain
* externally-adjustable ball differentials (front/rear)
* ball diffs are factory preassembled for smooth operation
* high-efficiency drive train featuring 24 high-speed ball-bearings
* ball bearings degreased and lightly oiled for maximum speed
* adjustable brake
* laser cut, hand-ground steel brake disk
* Ferodo brake pads for strong, fade-free braking power
* aluminium main driveshaft
* low CG
dairy 金牌 Fans 发消息
发表于 06-2-9 01:59:41 |显示全部楼层 来自: 中国广东广州
Suspension
* oil-filled coil-over shocks for precision dampening
* front and rear anti-roll bars
* fully independent suspension
* adjustable shock positions
* optimized suspension down- and up-travel
* adjustable front toe-in (rear optional)
* Hudy Spring Steel steering rods
* 36 nickel-coated steel pivot balls throughout the suspension
* steel spur gear for dusty tracks
dairy 金牌 Fans 发消息
发表于 06-2-9 01:59:53 |显示全部楼层 来自: 中国广东广州
Extras
* racing style dish wheels
* rubber low pin tires with foam inserts
* 1/18 racing truck body included
* HUDY Phillips Screwdriver included
Available in two versions:
#380791 - XRAY NT18T + engine + muffler + 2x servo + receiver battery + connecting cables with integrated switch
#380700 - XRAY NT18T + engine + muffler
こ尛嘻苽ぢ 论坛元老 发消息
发表于 06-2-9 02:02:48 |显示全部楼层 来自: 中国上海
感觉前后油压架很容易死的样子...
唐乾钧 超级元老 发消息
发表于 06-2-9 03:59:58 |显示全部楼层 来自: 美国
原帖由 こ尛嘻苽ぢ 于 2006-2-8 13:02 发表
感觉前后油压架很容易死的样子...
有金属补品...
遥控大猫 超级元老 发消息
发表于 06-2-9 15:59:26 |显示全部楼层 来自: 中国北京
感觉还有很多很多有待op的地方...
