冷枫晓月 论坛元老 发消息
发表于 05-11-23 20:25:00 |显示全部楼层 来自: 中国江苏徐州
以下是引用kurt在2005-11-23 13:53:24的发言:
      [quote]以下是引用唐乾钧在2005-11-22 13:56:08的发言:
还是上个2pl吧,毕竟接收要小一点,可以好安排一点空间......还可以纯10的设置,价钱也公道....
  什么牌子的?有没有什么介绍?
[/quote]
是Futaba的,不过是AM两通道的,简单介绍看这里http://www.rcfans.com/bbs/dispbbs.asp?boardID=13&ID=30151
7610junjun 元老 Fans 发消息
发表于 05-12-27 17:46:00 |显示全部楼层 来自: 中国广东深圳
  不要买太好的!!!   买个 M11就可以拉~
唐乾钧 超级元老 发消息
发表于 05-12-29 06:07:00 |显示全部楼层 来自: 美国
  什么牌子的?有没有什么介绍?
[/quote]也是Futaba的
FEATURES: One-button programming for fast and easy menu access
          Ten model memory stores and selects preset programming for up to ten
            different models
          One trim switch allows setting and adjusting trims without returning
            to the menu
          Steering dual rate strategically located on the grip close to the
            trigger offers more mid-range control, crucial when cars are going
            into corners
          Steering/Throttle End Point Adjustment (EPA) limits servo travel for
            more control and to prevent servo damage
          ABS braking initiates on and off pulsing for less skidding and can be
            set for slow, mid, or fast pulsing
[upload=jpg]uploadImages4/2005122967942116.jpg[/upload]
