最近一直关注网上 看中了一套传动系统,
目前在特价销售中,价格还是蛮合适的
大家帮忙给看看 他的主要特点是什么?O(∩_∩)O谢谢
我英文太烂了 附上它的英文介绍
Baja Skunkworks 2-Speed Gearing designed specially for the HPI Baja.Over three years of development, several revisions, hundreds of man hours, broken relationships, blood sweat, and tears invested into this product, yes it really is rocket science.
All 2-Speeds are now shipping with the improved VBX one-way bearings. Which are reported to be working well in many high horsepower situations without failure.
- Bombproof for those 50lb billet Baja’s.
- Dual bearing supported second gear.
- Dual engagement pawls for solid positive shifting.
- Quad strike pins for maximum redundancy and solid shifting.
- Captured and supported strike pins, these pins will never fall off or out.
- All steel parts are heat treated for maximum wear and reliability.
- Manufactured from Nine different materials carefully selected for their qualities and matched to the components to achieve the ultimate performance and reliability.
- Includes your choice of gear sets: 51:23, 53:21, 48:26.
- Gears are made by world renowned RC gear specialist Robinson Racing. They are case hardened for maximum strength, wear, and reliability.
- The shift point is externally adjustable. Without the gear cover the shift point can be adjusted in a matter of seconds.
- The shift point is designed to be set and never lose adjustment. Other designs do not have this feature. As a result the shift point has to constantly be reset.
- First gear is designed around the OEM HPI Baja spur gears. You can use any gear combination that is compatible with the HPI gear carrier and clutch system
- Includes a vacuum formed ABS gear cover and stand-offs.
- Designed to work exclusively with the Turtle racing HD clutch system and your choice of Turtle pinion and matching spur.
