关于捕蛇者说。
查看: 3508|回复: 14|   [复制链接]
yanghaoyanghao 论坛元老 发消息
发表于 11-4-21 18:24:42 |显示全部楼层 来自: 中国北京
老是琢磨换个排气,今天看到T---B有个排气价格不贵名为:捕蛇者,在坛子里待了一年多了,还真没看到有几个人用的,现求助用过此管的模友给点建议或意见。谢了!
q309747644 元老 Fans 发消息
发表于 11-4-21 18:25:39 |显示全部楼层 来自: 中国广东广州
沙发沙发~~~
fwzflqwer 超级元老 发消息
发表于 11-4-21 18:33:02 |显示全部楼层 来自: 澳大利亚
给个图片,名字太不准确了
发表于 11-4-21 19:12:21 |显示全部楼层 来自: 中国北京
阳光人 元老 Fans 发消息
发表于 11-4-21 19:14:08 |显示全部楼层 来自: 中国山东临沂
km 的龙管。。。。效果和支配着一样。
发表于 11-4-21 19:16:42 |显示全部楼层 来自: 中国北京
回复 阳光人 的帖子
用过没?啥效果,不会跟支配者一样吧。
阳光人 元老 Fans 发消息
发表于 11-4-21 19:18:38 |显示全部楼层 来自: 中国山东临沂
效果和支配着一样,这是老板说的,,没用过
发表于 11-4-21 19:25:42 |显示全部楼层 来自: 中国北京
哦了,多谢LS解释。
待业、小靑年 RC 新手 发消息
发表于 11-4-21 20:05:36 |显示全部楼层 来自: 中国河北唐山
这管子就是 支配者的 缩版
fwzflqwer 超级元老 发消息
发表于 11-4-21 20:16:15 |显示全部楼层 来自: 澳大利亚
回复 yanghaoyanghao 的帖子
这款排气是仿造DDM的一款,是在支配者的基础上改进的,国产的精度和材质都差不少,找不到正品的谐振点
制造商是UnderRC
这里有这款排气的详细数据
Here at UberRC we are very proud to finally announce our Rear Mounted Tuned Exhaust Pipe for the Baja 5b & 5T. Designed from the ground up for bashers and racers alike, this pipe offers excellent smooth progressive power throughout the entire throttle range. Made from high grade Stainless Steel it offers excellent durability ideal for the harsh environments your Baja gets put through, with no risk of rusting and being extremely durable it can take the knocks every pipe gets from time to time.
Designed for ease of fitting, the laser profiled bracket is extra wide to give a solid base onto your rear lower chassis & features 2 bolt holes so theres no risk of movement which can cause mounting brackets to fail prematurely.
With a detachable header piece and slim profile this pipe slips in and around the rollcage and supporting struts to allow quick & easy fitting & removal without touching any plastic parts that may be at risk of melting. This pipe has been designed for use with 2 stroke engines and has been Dyno tested to maximise performance, results have been excellent, please see the graph below for a comparison between this pipe and the popular Dominator pipe.
Weight of this pipe is: 627g
We've also worked closely with Dave at DDM on this pipe as we didn't want to be seen as simply doing a Dom clone pipe, heres what he had to say: "I don't see any problem with this pipe at all - yes it could be considered somewhat similar, but it is also very, very different. You won't have any problems from our end. Thanks."
