Hpi Pro4 2005 edition
查看: 4490|回复: 15| [复制链接]
skyjack 高级 Fans 发消息
发表于 05-4-3 14:53:00 |显示全部楼层 来自: 中国广东广州
眼睛有问题吗?
以下是引用马达王在2005-4-3 0:11:18的发言:
请问一下都改进了什么地方
All standard Pro 4 features
+2.5mm main chassis (original main chassis)
+new upper deck (as shown -- more lateral flex, same fore to aft stiffness, reduced chance of tweaking on impacts, with cone washers and o-rings over the steering posts as used by Hara) +new motor mount (as shown)
+new shocks (fluorine coated, new bladders, new pistons, new shafts, as shown)
+Delrin diff out drives
+new 1 piece aluminum rear input shaft (combines spur adapter and shaft, with solid pins, much more rigid gear mounting, different than Japanese spec parts)
+new aluminum front input shaft
+new diff nut and new diff screw (larger screw size + T-nut)
+aluminum steering servo mounts
+Spool and One Way will be included
+full range of pivot block spacers to adjust block heights
+0, 2.0, 2.5 and 3.0 degree pivot blocks included
+Heavy Duty, Self Lubricating Ball Cups are also included
发表于 05-4-3 17:46:00 |显示全部楼层 来自: 中国广东广州
因为是英文才问的
council 长老 Fans 发消息
发表于 05-4-3 20:09:00 |显示全部楼层 来自: 中国广东广州
以下是引用马达王在2005-4-3 17:46:10的发言:
因为是英文才问的
奥敌公司不用英文的?[em51][em51]
发表于 05-4-4 21:33:00 |显示全部楼层 来自: 中国广东广州
翻译中
H-TC RC 新手 发消息
发表于 05-4-5 10:50:00 |显示全部楼层 来自: 中国浙江杭州
我爱那两颗金属伞齿
