The USA/ Europe 2005 Spec Pro 4 will have the following: All standard Pro 4 features +2.5mm main chassis (original main chassis) +new upper deck (as shown -- more lateral flex, same fore to aft stiffness, reduced chance of tweaking on impacts, with cone washers and o-rings over the steering posts as used by Hara) +new motor mount (as shown) +new shocks (fluorine coated, new bladders, new pistons, new shafts, as shown) +Delrin diff out drives +new 1 piece aluminum rear input shaft (combines spur adapter and shaft, with solid pins, much more rigid gear mounting, different than Japanese spec parts) +new aluminum front input shaft +new diff nut and new diff screw (larger screw size + T-nut) +aluminum steering servo mounts +Spool and One Way will be included +full range of pivot block spacers to adjust block heights +0, 2.0, 2.5 and 3.0 degree pivot blocks included +Heavy Duty, Self Lubricating Ball Cups are also included |
