nivea 金牌 Fans 发消息
发表于 09-7-18 13:23:33 |显示全部楼层 来自: 中国广东广州
The remarkable 2.4GHz control unit is pre-installed on this palmtop-sized Formula racing machine which is just 182mm in length. Previously only available on the Formula model as an option, the 2.4GHz unit not only eliminates the stress of managing frequency bands but also adds performance to please drivers looking for even more speed. To make it even more economical, this kit is packaged without transmitter so you can use your existing ASF 2.4GHz transmitter, making it ideal as a 2nd or 3rd addition to your MINI-Z collection. Add your favorite F-1 team’s body and start living your own scale Formula racing dream!
Available: August
Features
  • ASF 2.4GHz – Switch the ASF 2.4GHz unit ON to start racing. Eliminates need to organize frequency bands. Includes ESC with double the FET capacity of previous version.
  • Coil Suspension – Precision king pin and coil suspension design on front enhances both speed and control.
  • Traction Control – Coil and twin arm swinging rear suspension delivers superb tracing and traction control
  • Stable Cornering – Red anodized differential realizes stable cornering. Includes 4 pinion gears so settings can be adapted to different types of courses.
  • Precision Steering – High resolution steering servo realizes precision steering control. Mass concentration also contributes to the superior maneuverability of the one-piece chassis structure.
  • Gold Plated Terminals – Special black chassis features gold plated spring battery terminals. For its low resistance, high rigidity and high conductivity, this is a must have racing item.
  • Stay Cool – Equipped with aluminum motor mount anodized in red functions as a heat sink for effective heat dissipation.
  • Equipped w/ Bearings – Ball bearings are included through the drive train and rotating parts for high efficiency energy transfer. Designed and equipped throughout for maximum performance.
  • X-Speed – Equipped with a X-Speed motor to give you that throttle punch you want.
  • High Grip Tires – Front 30(shore) Rear 20(shore)
  • FA-4B FET – The ultra low C of G of the Formula chassis now includes the RA-4B FET amp.
  • Perfex KT-18 2.4Ghz Transmitter – *Transmitter Not Included. Using 2.4GHz frequency, the transmitter and chassis automatically lock on to open bands with the 2.4GHz ASF system. Realizes a stable environment without interference so you can have confidence in your radio system’s response. Allows up to 40 cars to be raced at the same time. Simple pairing process (registering transmitter with the chassis) also enables a single transmitter to be used with multiple chassis. The next generation of proportional radio control systems starts here.
Chassis Set w/out Transmitter Contents
  • Pre-assembled chassis installed with R/C Unit (incl. brake & reverse functions)
  • Pinion gears (4 types)
  • Removable clear bumper
  • Wheel wrench
  • ASF 2.4GHz
Required For Operation
  • Perfex KT-18 transmitter # 82001
  • 4 x AAA-size batteries for transmitter
  • 4 x AAA-size batteries (alkaline or Ni-MH) for chassis
  • Body Set
nivea 金牌 Fans 发消息
发表于 09-7-18 13:24:16 |显示全部楼层 来自: 中国广东广州
nirunyu 高级 Fans 发消息
发表于 09-7-18 14:15:03 |显示全部楼层 来自: 中国安徽芜湖
好强啊,看来价格不便宜啊,不知道对场地要求高不高
bo68674 超级元老 发消息
发表于 09-7-18 14:23:33 |显示全部楼层 来自: 中国广东佛山
转向悬挂改了?
nirunyu 高级 Fans 发消息
发表于 09-7-18 14:30:15 |显示全部楼层 来自: 中国安徽芜湖
扭腰怎么不见了?
gzkanu 金牌 Fans 发消息
发表于 09-7-18 14:36:26 |显示全部楼层 来自: 中国广东广州
改变了没有关系 配件少和配件贵才是大问题
xiatian118 论坛元老 发消息
发表于 09-7-18 20:01:43 |显示全部楼层 来自: 中国天津
楼上同学说的没错,这个配件太少见了
321go 超级元老 发消息
发表于 09-7-18 21:19:12 |显示全部楼层 来自: 中国北京
LS是不是有日子没来车场了
这车我都惦记很长时间啦
车趣 超级元老 发消息
发表于 09-7-18 22:53:50 |显示全部楼层 来自: 中国陕西
只能看了
veyron7460 金牌 Fans 发消息
发表于 09-7-19 09:39:57 |显示全部楼层 来自: 中国江苏南京
貌似没有避震,对场地平整度要求高啊
