nivea 金牌 Fans 发消息
发表于 09-2-11 00:40:34 |显示全部楼层 来自: 中国广东广州
The Serpent S240 is a 1/24 scale electric 2wd pan-car. Simple, fast, proven and strong design. No complicated suspension designs or set-ups. A pure fun racing chassis, for sheer endless amounts of track-time. - top quality carbon fibre chassis components with flex-control - cnc machined and orange anodised aluminium parts - smooth ball-diff - high speed bearings, metric high quality screws - designed for Lipo packs for over 15 minutes runtime - electric brushed motor - High grip foam racing tyres - Low profile, GT style body
Front end S240
Front end  consists of carbon fibre and aluminium components, attached to the chassis, pivoting on 2 soft silicone grommets, creating excellent front end grip.
Machined aluminium steering blocks with nylon insert for smooth operation, captured by upper and lower carbon fibre brackets.
Adjustable toe in combined with durable anodized track-rods for precision-steering.
Body-shell
The nicely designed GTP type body-shell in lightweight 0,5mm material, for great looks and superb handling.
Protection
Rear bumper to absorb the impact of fellow race-cars hitting from the back, and protect foam tyres and main gears from hits.
Wheels, tyres and adaptors
Machined aluminium rear wheel-adaptors for super-true running rear wheels.
Foam racing tyres on closed dished type wheels.
Motor
The S240 micro electric brushed motor powers this micro-verhicle.
Motorpinion 10T is standard ( other as optionals).
Ball-differential
The ball-raced ball-differential operates with plates and 12 steel balls.
Standard with 42T white gear.
Rear end
Rear motorpod consist of 2 equal machined anodized aluminium motormounts, mounted on 2 carbon chassis-risers, which can be taken out as well, depending on surface.
Carbon fibre top-plate connects the motormounts and created the rear end stability and stiffness. There is sufficient space for the motorcables-to be connected.
Lipo Power
The 2 or 4 Lipo-cells (not included) are captured in this lexan holder, below the radioplate.
Pack sits very low and central in the car for best weight distribution, which helps ultra-quick and stabile cornering.
Upper-deck
Carbon fibre upper radioplate with anodized aluminum antenna-holder.
The S240 accepts speed-controllers for micro-cars of the major brands.
Central rear vertical dampening combined with a laid down rear shockabsorber to control the rear end of the car.
Anodised aluminium bodyposts on the far corners.
Carbon fibre chassis 1.2mm with integrated T-bar flex design, 2 slots to assist keeping the lexan battery-holder in place.
Bumper and servo position
Strong nylon front bumper with machined, anodised aluminium body-posts.
Sufficient space for the lay-down micro-servo 30×30mm ( not included)
Serpent S240 kit
Serpent S240 comes complete with full color manual, reference guide and decals, in a handy small box, in which you can carry the ready-to race car and more.
llw00549 论坛元老 发消息
发表于 09-2-11 21:50:50 |显示全部楼层 来自: 中国辽宁大连
感觉有点奇怪……
pal 超级元老 发消息
发表于 09-2-11 22:13:53 |显示全部楼层 来自: 中国上海
像当年广坂的ABC DTM一样,拿来练习很不错的
不知道价格怎么样
winine 论坛元老 发消息
发表于 09-2-11 23:19:55 |显示全部楼层 来自: 中国浙江杭州
这估计便宜不了啊!!!!!
hhb1969 终极 Fans 发消息
发表于 09-2-12 15:45:52 |显示全部楼层 来自: 中国广东广州
咿,终于有新野咯,5知表现如何呢?
x57 终极 Fans 发消息
发表于 09-2-12 16:15:39 |显示全部楼层 来自: 中国北京
小车不便宜
老玩童david 终极 Fans 发消息
发表于 09-2-13 10:03:19 |显示全部楼层 来自: 中国江苏扬州
顶 . . .
小仲 超级元老 发消息
发表于 09-2-13 14:23:39 |显示全部楼层 来自: 中国广东广州
咿,终于有新野咯,5知表现如何呢?
hhb1969 发表于 09-2-12 15:45
何局。。。我们的场地不适合海绵胎啊。。
hhb1969 终极 Fans 发消息
发表于 09-2-13 17:31:13 |显示全部楼层 来自: 中国广东广州
何局。。。我们的场地不适合海绵胎啊。。
小仲 发表于 09-2-13 14:23
甘你就搞多一个适合跑海绵胎的场啦,我会支持你的,哈哈!!!!
小仲 超级元老 发消息
发表于 09-2-13 17:32:00 |显示全部楼层 来自: 中国广东广州
hhb1969 发表于 09-2-13 17:31
有你的赞助就马上搞!!
