No. 30440FA-B MR02LM ASF CCS PORSCHE 962 C KH No. 27, 2009年2月推出市场。这款车壳是以1988年首次参加全日本耐力赛的原型车为蓝本开发的,赢得富士500公里赛事等殊荣。
Newly developed 2.4GHz R/C system requires no frequency crystals and automatically scans open frequencies to use, allowing up to 40 cars to be run together. Simply switch the power on for stable control without interference. The fastest signal processing in the history of R/C results in almost instantaneous reaction to the driver’s will for a more direct control feel. By pairing the transmitter to the chassis, a single transmitter can be registered and used with multiple 2.4GHz MINI-Z models. To match the latest R/C technology, a new generation LM chassis has been developed for even greater performance. The 3L size long wheelbase chassis enables the motor to be set 5.5mm lower (than the MM motor case) and laterally centered. In addition, small diameter wheels on the front and newly designed knuckle arms drop the chassis height by a further 1mm.
Specific front and rear wheel diameters and tires recreate the real Le Mans car dimensions. Ultra fast signal processing produces direct driving control. Equipped with FET amp with more than double the capacity of previous versions and includes LED indicator that lights up when power is switched ON. Features newly designed front knuckle to match the specific dimensions of the front wheel and tires. Realizes plenty of suspension stroke even on low clearance Le Mans cars. New design chassis results in the fastest MINI-Z ever with quick control response. Revised reverse control and enables pumping brake action. - ASF 2.4GHz system automatically scans for open frequencies and promises safer and more secure control.
