[upload=jpg]picture/onroad/200481720262413202.jpg[/upload] Hey touring car fans are you ready to turn heads? If so, then check out the latest in tire technology - Packin’ Heat. The TC Series Packin’ Heat tire incorporates a unique inner webbing that eliminates the use of foam inserts. It also resists expansion of the tire under acceleration and at high speeds. Another unique attribute of the Packin’ Heat tire is the tread design. Instead of traditional style tread, it incorporates a highly detailed flame design. The flame design is user friendly on a variety of surfaces and maintains the consistent traction needed to work in a variety of conditions. The TC Series Packin’ Heat tire fits directly on a variety of 1.9” x 26mm wheels. When you’re looking to update you TC with the latest in tire technology, then check out the new TC Series Packin’ Heat tire from Pro-Line. ? Features: · Unique flame tread · Unique inner webbing eliminates the use of foam liner and resists expansion under high speed · Made from durable yet performance-minded rubber compound · Designed to fit all of today’s popular 26mm touring car wheels ? |
