No. 30568R-B MA-010 r/s Alfa Brera Red
No. 30568S-B MA-010 r/s Alfa Brera Silver
Available: Now
The BRERA has Alpha design and the Italian flare of Giugiaro who oversaw the development all over it. With the signature Alpha Romeo front grill, the unique rear windows and rear combination lights stamp the BRERA’s style that is backed up with matching powerful yet sophisticated performance. If there is a real AWD vehicle out there, you can expect it to appear as a Mini-Z AWD. Of course, the Mini-Z AWD (All Wheel Drive) chassis maintains its high performance and sophisticated technology, as well as the incredible attention to detail. The Mini-Z also manages to achieve its shaft-driven AWD system in its minimal size with a precision king-pin strut system 4-wheel independent suspension. In addition, the high efficiency drive system features a specially shaped crown gear and pinion gear in the newly designed diff gear unit. The result is a level of resistance through the drive train about the same as existing 2WD versions to produce true racing machine performance.
Midship motor mount with shaft driven AWD for optimal balance. 4-wheel independent suspension with king-pin strut system realizes excellent running stability & performance. Factory assembled chassis comes with R/C unit installed and features new “RA-12″ receiver unit with built-in speed control amp with 30% more capacity. Equipped with precision manufactured universal swing shafts on all wheels to communicate drive power with maximum efficiency and allow smooth movement of suspension system. All Wheel Drive system features diff gear unit with precision 3-bevel gears and specially shaped cogs on crown and pinion gears. - One-touch removal/attachment of optional tie-rods allow easy adjustment of toe angle.
