Schumacher Cougar KR 2WD 电越
13-9-12 00:33| 发布者: rcfans| 查看: 11096| 评论: 7
http://www.racing-cars.com/pp/Car_Showroom/images/Cougar_KR_R_deck_1000.jpg
http://www.racing-cars.com/pp/Car_Showroom/images/Cougar_KR_fr_shock_1000.jpg
http://www.racing-cars.com/pp/Car_Showroom/images/Cougar_KR_rear_hex_1000.jpg
http://www.racing-cars.com/pp/Car_Showroom/images/Cougar_KR_gear_diff_1000.jpg
特性
  • NEW Front Skid Plate - Reduces wear.
  • NEW Lower easy to assemble, wing mount system.
  • NEW All black anodised components.
  • NEW Gear Differential with hardened steel gears and super hard outputs.
  • NEW Hi-Tensile, revised style silver turnbuckles.
  • NEW Stronger front steering hub, with fine Kwik Klip Adjustment.
  • NEW 12mm Hex Wheels with clean look and industry standard offset.
  • NEW Super Strong 7075-T6 Alloy Anti-Squat plate.
  • NEW Recessed alloy chassis - Low centre of gravity for LiPo batteries & neater wiring.
  • NEW Rear top deck mount - Optimised chassis flex.
  • Large range of front to rear battery positions - Allows weight distribution tuning for each track.
  • Moulded chassis sides - Fantastic dirt seal with no handling compromise.
  • Maximum dimension wing. Superb airflow control and max down force.
  • “Super Cool” 7075-T6 Alloy  motor plate. Offers a greater surface area and thickness, for improved cooling and rigidity.
  • Pro spec 13mm big bore shocks with titanium nitride shafts, CNC machined 3 hole pistons with recessed ‘e’clips, threaded collars, twin O ring sealing and diaphragm volume compensation.
  • Longer front wishbones - Improved corner speed.
  • Stronger front bulkhead and bottom plate.
  • 24 piece “Red Seal” ball bearing set.
  • PTFE coated shock bodies - Hard, with a super smooth shock action.
  • CVA style driveshafts - Increased drive.
  • Excellent centre line balance.
  • Fully optimised suspension geometry - Fast, consistent handling.
  • Moulded gear cover for great spur gear protection.
  • Rear motor & three geared transmission - Excellent grip on low traction circuits.
12
    引用 蝎子没有毒 13-9-13 19:16
    完美2WD
    引用 Lu°远 13-9-12 18:14
    求突破性技术啊~
    引用 凡阿特 13-9-12 17:24
    图的问题吗,感觉好宽
    引用 聪哥 13-9-12 08:56
    感觉相当不错!
    引用 chaizgg 13-9-12 08:25
    型宽 体胖
    引用 shi995800 13-9-12 07:22
    两驱是门艺术~~~~~~~~~~
    引用 李亮 13-9-12 05:12
    看起来好像不错哦
    查看全部评论(7)
