Features: - Ultra-smooth and Precise Throttle and Braking Control
- Compatible with Sensored/Sensorless Brushless and Brushed Motors
- Easily Access Programming, Anywhere, Anytime
- Datalogging Capability
- High Voltage Programmable BEC
- EZ Access HotWire Programming Port
- HotWire PC Interface for Advanced Programming and Updating
- D2: Dual Drive Mode Technology
- On-Board Temperature Indicator
- Removable/Replaceable Cooling Fan
- HDAC: High Density Copper PCB’s
- Sensor Plug for Precise Commutation with all Motors
- Gold-plated Solder Posts for Easy Wire Replacement
- Self Test Diagnostics and Factory Reset
- Pit Tune Mode
- DGF2: Digital Glitch Filtering V2
- QuickTune™ Programming
- One-Touch Radio Calibration
30mm RX8 Fan Included #TT3832 - High airflow volume for extreme cooling
- Impact resistant durable design for offroad applications
- Brushless Motor
Program Features: - High Voltage BEC (6.0v/7.4v)*
- Drag Brake (13 steps)
- Brake / Reverse Strength (13 steps)
- Current Limiter (none + 12 steps)
- Neutral Width (13 steps)
- Timing Profiles (5 preset – 2 custom*)
- Adjustable Throttle and Brake Minimums
- Custom Throttle Curves
- Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
- Voltage Cutoffs (none, 2S, 3S, 4S, 5S, 6S, Custom)
- Save, Load and Share custom ESC setup files*
- Save, Load and Share Data Log files*
- Extensive Tuning via Tekin HotWire PC Interface
*Requires HotWire Sold Separately Specs: Controls: Forward/Brake/Reverse Input Voltage: 2S-6S Lipo BEC: 6.0v / 7.4v 7amps Motor Limit Brushless Mode: No Limit Motor Limit Brushed Fwd Only Mode: No Limit Motor Limit Brushed Fwd/Rev Mode: No Limit Max Current: 220amps per phase Timing Profiles: 7 choices (on board) Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay Dimensions: 1.5 x 2.2 x 1.4in (38 x 55.8 x 25.5mm) Weight: 2.7oz / 76.5g
