新特性
XB9’13 – New Features:
- New longer and wider chassis for increased stability and weight balance
- New engine position and internal component layout to improve performance, efficiency and durability
- New updated side guards
- New fuel tank with floating stone type fuel filter
- New high-torque clutch set
- New heavier high-torque flywheel
- New high-torque clutch shoes
- New high-torque clutch springs
- New 16° caster blocks suitable for majority of track conditions
- New steering blocks for increased corner speed
- New Ackermann position for increased corner speed
- New Hudy Spring Steel turnbuckles with – New size
- New front shock tower with – New roll center positions
- New rear shock to accommodate optional longer chassis brace
- New longer muffler mounting to accommodate all types of mufflers
