AE TC6.1 Worlds car kit
12-10-5 11:22| 发布者: rcfans| 查看: 18989| 评论: 8
Features
  • Ultra-narrow 2.25mm-thick carbon-fiber chassis
  • Factory Team vertical ballstud bearing caps with carbon-fiber shock towers
  • Suspension arms designed for increased stiffness and strength, as well as finer shock adjustments
  • Hubs and caster blocks use integrated inserts for adjustable caster/toe angles
  • H.D.R.C. (High Definition Roll Control) system
  • Lightweight rear gear diff for maximum performance and minimal maintenance
  • Front spool with replaceable composite outdrives
  • Offset arm mounts help increase durability and minimize shims between mount and bulkhead
  • Ultra-narrow chassis layout optimized for LiPo batteries and brushless motors
  • Symmetrical bulkhead layout minimizes spare part cost
  • Multi-position steering system to fine-tune Ackermann steering rates
  • VCS3 Shocks with hard-anodized threaded shock bodies
  • Titanium turnbuckles with new ballcup eyelets for easy access to ball stud
  • 16 precision ball bearings
  • Cross-compatibility with TC6 chassis component
http://cdn8.rccaraction.com/wp-content/gallery/team-associated-tc6-1-factory-team-worlds-car-kit/tc6-1worlds-chassis.jpg?8a12f1
http://cdn9.rccaraction.com/wp-content/gallery/team-associated-tc6-1-factory-team-worlds-car-kit/tc6-1worlds-chassis-profile-l.jpg?8a12f1
http://cdn6.rccaraction.com/wp-content/gallery/team-associated-tc6-1-factory-team-worlds-car-kit/tc6-1worlds-chassis-lr.jpg?8a12f1
http://cdn8.rccaraction.com/wp-content/gallery/team-associated-tc6-1-factory-team-worlds-car-kit/tc6-1worlds-chassis-front.jpg?8a12f1
http://cdn9.rccaraction.com/wp-content/gallery/team-associated-tc6-1-factory-team-worlds-car-kit/tc6-1worlds-body-blackbg-ul.jpg?8a12f1
http://cdn7.rccaraction.com/wp-content/gallery/team-associated-tc6-1-factory-team-worlds-car-kit/tc6-1worlds-body-blackbg-lr.jpg?8a12f1
http://cdn4.rccaraction.com/wp-content/gallery/team-associated-tc6-1-factory-team-worlds-car-kit/30108-spool-ps_.jpg?8a12f1
http://cdn9.rccaraction.com/wp-content/gallery/team-associated-tc6-1-factory-team-worlds-car-kit/30108-shocks-ps_.jpg?8a12f1
12
    引用 ACGFANS 12-10-9 17:58
    piggypf: 貌似真找不到啥亮点。
    亮点就是:毫无亮点!
    引用 piggypf 12-10-9 09:42
    貌似真找不到啥亮点。
    引用 竞速大师杯 12-10-6 21:14
    凡阿特: 新手买这车就准备不停换波箱吧,美国人的设计不行啊
    波箱没问题啊?什么事都没有啊。。。
    引用 ACGFANS 12-10-6 19:36
    chu97: 搞不懂美国人,这个怎么看都像怀旧版,单柱转向,纵置舵机
    ...不然6.2 6.3 6.4 .6.5搞什么啊! 难道搞核动力还是反物质引擎!
    引用 chu97 12-10-6 14:51
    引用 凡阿特 12-10-5 20:14
    chu97: 臂码和波箱合为一体。。。
    引用 chu97 12-10-5 13:55
    臂码和波箱合为一体。。。
    引用 reiyagami 12-10-5 11:29
    窄底盘 等你很久了 现在就等发售
    查看全部评论(8)
