Losi 1/24 Micro Truggy RTR
12-3-3 00:10| 发布者: rcfans| 查看: 11511| 评论: 10
Features:
  • Long-lasting battery pack and charger
  • 2-in-1 ESC/receiver combo unit
  • Powerful micro motor
  • Adjustable, composite, coil-over shocks
  • Durable, molded composite chassis
  • Shaft-driven transmission gear differential
  • Micro all-terrain Kingpin tires
  • Simple bottom-load battery compartment
  • Threaded axles (no e-clips required)
  • Dish racing wheels
  • Micro steering servo
  • Fully decorated truggy body
Specifications
Type: 4WD Micro Truggy
Scale: 1/24
Length: 6.13 in (156mm)
Width: 4.25 in (108mm)
Wheelbase: 4.18 in (106mm)
Weight: 5.3 oz (165g)
Chassis: Extended composite tub
Suspension: Independent 4-wheel
Speed Control: Electronic, fully proportional
Radio: Pistol-style AM 27Mz
Batteries: 4.8V 220mAh NiMH (included)
Charger: Peak wall charger (included)
Kit/RTR: RTR
Minimum Age Recommendation: 14 years
Experience Level: Beginner
Recommended Environment: Indoor/Outdoor
Is Assembly Required: No
欢迎进入RCFans迷你遥控车讨论区参与讨论
Source:http://www.horizonhobby.com.cn/
12
    引用 nightsun 12-3-4 17:28
    很喜欢这样的车型~~
    引用 shi995800 12-3-4 15:02
    现在越野都流行往小的发展了~~
    引用 咸萝卜勇士 12-3-3 21:56
    额,LOSI又出24仔了,看上去还不错。。
    引用 geliao117 12-3-3 15:09
    这个和现在micro sct的地盘一样啊,该无刷的话直接上micro sct的无刷套装就行了,不过电池不给力,我以前5分钟就没电了
    引用 trouble 12-3-3 11:52
    5线舵机,二合一AM接收,这个有点……不过LOSI四驱的24仔,还是值得期待的,希望上市后不要太贵
    引用 groovyice 12-3-3 11:21
    四驱不容易啊
    用的是五线舵机?
    引用 ledledled 12-3-3 09:21
    无刷吗?
    改无刷用什么套装?
    引用 hjbmax 12-3-3 00:51
    这货卖的到好多?
    引用 rolayyalor 12-3-3 00:28
    LOSI的东西绝对比JS的要结实吧
    引用 ferrarifan 12-3-3 00:15
    这货是不是来对抗KYOSHO的MINIZ BUGGY啊???
    查看全部评论(10)
