Losi迷你拉力和短卡
12-2-6 16:59| 发布者: admin| 查看: 10489| 评论: 13
Losi在德国纽伦堡展会上已经展出了全新的1/24 RTR四驱遥控车系列,这个车系有拉力和短卡两种不同车款。全部装备8750Kv无刷系统,车速超快!无论是室内或室外都能体验到高速带来的快感。遥控设备使用了Spektrum 2.4GHz DSM遥控设备。直轴传动,齿轮差速。原厂像真拉力车壳或短卡车壳。LOSI的1/24新车相信是充满乐趣的产品。
4wd Rally car features
- Two-in-one brushless ESC/2.4GHz DSM receiver combo unit
- Powerful 8750Kv brushless micro motor
- Adjustable composite coil-over shocks
- Durable, molded composite 4WD chassis
- Shaft-driven transmission gear differential
- Micro all-terrain rally car tyres
- Simple bottom-load battery compartment
- Threaded axles (no E-clips required)
- Euro-style rally wheels
- Micro steering servo
- Side nerf bars for collision protection
- 4.8V 220mAh rechargeable battery pack and charger
4wd Rally car specifications
Length: 163mm (6.42 in)
Width: 94.5mm (3.72 in)
Wheelbase: 99mm (3.9 in)
Weight: 165 g (5.3 oz)
Chassis: Extended composite tub
Suspension: Independent 4-wheel
Radio System: Pistol-style 2.4GHz DSM
Speed Control: Brushed/brushless, LiPo compatible
Battery: 4.8V 220mAh NiMH (included)
Charger: Peak wall charger (included)
Short Course Truck features
- 4.8V 220mAh battery pack and charger
- 2-in-1 brushless ESC/2.4GHz DSM receiver combo unit
- Adjustable composite , oil-filled, coil-over shocks
- Durable, molded composite chassis
- Micro all-terrain short course tires
- Threaded axles (no e-clips required)
- Beadlock-style Short Course wheels
- Realistic front and rear bumper with skid plates
Short Course Truck specifications
Length: 6.42 in (163mm)
Width: 3.72 in (94.5mm)
Wheelbase: 3.9 in (99mm)
Weight: 5.3 oz (165 g)
    引用 wyvernxt 12-2-8 19:38
    都升级成2.4 无刷了,为啥电池不 ...
    引用 87381085 12-2-8 18:26
    莫非想打击经商MINI-Z 1/24的天下??有的话搞台研究下
    引用 空中挥舞 12-2-7 19:17
    小车好 ^_^
    引用 tommy00 12-2-7 18:44
    难道短卡也要配扭腰?
    引用 咸萝卜勇士 12-2-7 18:06
    哈哈,比有刷小车好了不少,就是电池坑爹,以后一定要买辆。。
    引用 shi995800 12-2-7 13:53
    太小了就不好玩了
    引用 jackhsu 12-2-7 09:55
    220mah NiMH 会不会太小了啊.
    引用 jl789 12-2-7 00:22
    大车玩习惯了 感觉小车太 ........
    引用 hjsabdh 12-2-6 23:01
    说不定小巧却很牢靠呢,顶这车,什么时候出来?。得弄个玩玩
    引用 zwtnt168 12-2-6 19:44
    这车转向不足,转个弯半径老大了,赶上我那自行撤了,我操!
    引用 zxpalm680 12-2-6 19:08
    电池啊电池,220mah,能用多久?
    引用 炎焱 12-2-6 18:22
    RTR 电池容量真小。。。
    引用 super_弟 12-2-6 17:44
    不知车架是否禁得起摧残。。。。。。。。。
    查看全部评论(13)
