TLR Ten-SCT RTR
12-7-13 15:05| 发布者: rcfans| 查看: 7899| 评论: 11
Team Losi Racing(TLR)推出Ten-SCT短卡RTR版。装备了革命性的引擎启动系统(R.O.S.S.),玩家只需要通过原车配备的Spektrum DX2L 2.4GHz遥控器上的点火启动按钮就能遥控启动引擎,换句话说玩车连点火器都不用带了,更不用担心故障率高的手拉系统。RTR版的Ten-SCT有着竞赛级版本车架的基因,虽说是RTR产品,可是性能完全具备竞赛级实力。装配防水型舵机和密封接收机盒意味着无需担心任何天气,就连7.4V接收锂电和充电器都包含在产品内。1.8匹马力的3.4cc引擎提供强大的动力支持,相信这辆1/10四驱(三差速)油动短卡是狂飙和竞赛的有力武器。
革命性点火启动系统
Remote On-Board Starting System
Scale:1/10
Completion Level:Ready-to-Run
Length:524mm (21.34 in)
Width:295.8mm (11.65 in)
Weight:3.06 kg (6.75lb)
Wheelbase:334mm (13.15 in)
Chassis:Anodised Aluminium
Suspension:4-wheel independent long-travel
Shock Type:Aluminium
Drivetrain:4WD with 3 gear differentials
Differential:Sealed gear
Tyre Tread:Eclipse SCT
Engine Size:Losi 3.4cc
Radio:Spektrum DX2L
Servos Included:Yes
Body:Losi SCT
Ball Bearings:Complete
Recommended Environment:All-Terrain
Fuel Tank Capacity:82cc
• R.O.S.S. - Remote On-board Starting System
• Spektum DX2L Transmitter
• Waterproof, sealed radio box
• Waterproof steering and throttle servos
• Lightweight anodized aluminium chassis
• Oversized 12mm anodised, threaded shocks
• Heavy-duty, 4mm tie rods with captured ends
• Twin disc brakes for quick and reliable 4-wheel stopping
• Tank clunk for fuel pickup even when rolled over
• 2-shoe centrifugal clutch
• 12mm wheel hexes
• Eclipse Short Course truck tyres
• Beadlock-style SCT wheels with rings
• Functional mud flaps
• Losi 3.4cc performance engine with slide-valve carburetor
• High-performance tuned pipe designed to maximize the 3.4's potential
• Two-stage air filter system to ensure a clean air intake
• Sway bars included for better control and handling
• 7.4V LiPo receiver battery pack and charger included
欢迎进入地平线模型品牌专区参与讨论,点击这里进入
    引用 ak47000 12-7-17 11:43
    发动机上装个启动马达,来启动发动机?
    引用 蠱惑肖 12-7-16 11:19
    这个要多少钱啊 什么时候有卖??
    引用 马环宇 12-7-15 11:25
    好车
    引用 V8赛车 12-7-15 09:59
    拉风车壳
    引用 nightsun 12-7-15 00:59
    好车 !!!!!!!!!!!!!!!!!!!!
    引用 自由大帝 12-7-13 23:14
    meng1987: 貌似很N啊,是不是和油老鼠一样的启动方式?
    遥控打火系统啊~~~
    引用 meng1987 12-7-13 22:12
    引用 邦德座驾 12-7-13 20:20
    中毒了,可是油车跟我无缘的。车壳非常拉风 。losi 的设计总是这么眼前一亮 。
    引用 林四海 12-7-13 18:36
    以前的tent遥控器和启动装置出现了很多问题。也不知道这个有没有所改进。看样子遥控器换应该能改善遥控距离短的问题。
    引用 zhukenda123 12-7-13 18:24
    TEN-T的好兄弟 啊哈哈哈
    引用 yu43085251 12-7-13 17:11
    查看全部评论(11)
