Features - NEW 2mm Aerospace carbon fibre “Soft Weave” chassis and long top deck with optimised flex. Easier to drive with more traction.
- NEW Extreme lightweight 7075-T6 transmission housings.
- NEW Anti-Roll Bar system, lightweight with a near linear response.
- NEW Bridged layshaft mounting with quick release layshaft design for ease of maintenance.
- NEW CNC alloy, 20 tooth layshaft pulley.
- NEW Steering geometry incorporating centre point steering with forward facing balls to fine tune geometry. Fully adjustable Velocity Ratio, Ackermann Angle and Ackerman Rate.
- NEW Stiff 3mm rear shock tower with more shock mounting positions.
- NEW Carbon Fibre wishbones with moulded Roll Bar Ball, for increased traction, lighter weight and better impact absorption.
- Clamp motor mount to adjust side to side weight distribution. The car can be perfectly balanced with different lipo batteries and radio gear.
- Split rear transmission housing.
- Carbon fibre upper link design with options to adjust roll centres.
- Anti roll bar mounts with precise vernier adjustment to minimise play.
- Purple Alloy CNC ‘O’ ring retained wheel hexes.
- Lightweight moulded pivot blocks. Optional twin pivot block system allows infinite adjustment of roll centres, toe-in, anti-squat, and track width on front and rear.
- Fully adjustable, suspension geometry, wheelbase, caster, camber, roll centre, track width, ackerman, droop, front toe in/out, ride height. Anti dive, anti squat can be changed with Speed Secret parts.
- Efficient transmission with twin Kevlar belts and precision CNC pulleys.
- Alloy eccentric adjusters for optimum belt tension. Easy diff height adjustment to allow changes in drive shaft plunge. This can be used to increase or decrease traction.
- Symmetrical chassis layout with few screws minimises tweak.
- Ultra smooth Nickel-Teflon plated threaded alloy shock absorbers for extreme smoothness and durability.
- Lightweight machined diff pulley, Ceramic diff balls, aerospace thrust bearing.
- Narrow efficient thin back belts.
- Ultra lightweight front spool. Improved durability.
- Dedicated front & rear, reverse cup, high tensile steel, CVD driveshafts. Improves all round traction.Differential and spool plastic inserts “sliders”. Offer a lightweight, efficient driveshaft interface.
- Incorporating larger pins and joints, improves strength and durability.
- Lightweight foam bumper.
- High tensile spring steel pins.
- Purple alloy M3 nuts.
- Battery fixing with tape or optional battery strap.
