Team Associated公布了SC10 4x4 Ready-To-Run(RTR) 短卡的资料。RTR版本的SC10 4X4使用了密封设备箱,Reedy 550 SL无刷马达、防水XP SC700电子变速器,XP-3SS 2.4GZh 三通道遥控器,S2008MG大扭力金属齿轮舵机,三款厂家喷涂完成的车壳(Lucas Oil, Pro Comp 和Rockstar/Makita)。预计这款产品在9月上市。
Features:
- XP3-SS 2.4GHz 3-channel radio system with S2008MG high- torque, metal-gear steering servo
- Water-resistant, high-power, LiPo-ready XP SC700 brushless speed
control with heat sink fan and Deans Ultra Plug battery connector
- Reedy 550-SL 3500kV 4-pole brushless motor
- Water-resistant enclosed receiver box
- Unique dual gearbox drive train coupled together with a 5mm
heavy duty belt system with external tension adjustment
- 32-pitch front and rear gearboxes with sealed fluid-filled
differentials
- Decoupled center slipper clutch allows for front and rear wheel
drive to slip independently, resulting in more traction and stability
on bumpy track conditions
- CVAs with captured drive pins and heavy duty 6mm alloy axles
- 12mm hex drive KMC replica wheels front and rear with
aggressive short-course racing tires.
- Officially licensed replica championship short-course racing
body
- 13mm blue aluminum big-bore threaded shocks with low-
friction X-ring seals
- Composite modular tub chassis with low-CG and “low polar
moment” design
- Removable ESC tray for easy clean-up and maintenance
- Ball-bearing steering system with adjustable steering stops
- All-metric hardware and ball bearings throughout
