原帖由 herber 于 2007-8-14 07:57 PM 发表
依照上面看來改動的地方很少,除了二樓板加厚,使用了前後直軸???我對後面沒有差速有點懷疑,另外就是對後面齒輪箱固定方式改變,其他的都大同小異....,而且螺絲也不是鈦金屬,是普通的螺絲,所以個人感覺沒有 ...
我有点搞不懂,是2mm的二樓板, 2.5mm 的底板,还是2.5mm的二樓板, 2mm 的底板呢?
About the Model
- Race-spec direct drive system equipped with rear ball differential for quick acceleration.
- Double deck carbon fiber chassis features brand new 2mm upper deck, which is designed to help convert chassis roll into cornering speed, and 2.5mm lower deck.
- R/C system, tires, body, motor, ESC, running battery & charger separately required.
TRF415 MSXX Marc Rheinard Edition 2007 Specs:
Lower Deck 2mm carbon fiber (same as MSXX)
Upper Deck 2.5mm carbon fiber (new design) |
