2007年9月份田宫即将推出 1/10 TRF415 MSXX 马可 Rheinard 版本 . 货号:42104 日本零售价: 69800日圆 42104 1/10 R/C TRF415 MSXX Marc Rheinard Edition 2007 Availability: September Quantity Per Carton: 2 units Japanese Retail Price: 69,800 yen The new TRF Series continues to expand with its second chassis kit, the TRF415 MSXX Marc Rheinard Edition 2007. This chassis kit has the same specs and special parts as the one used by TRF driver Marc Rheinard to take his second consecutive victory at the Reedy Touring Car race in May of this year, making it perfect for those who want to stay on the cutting edge of R/C racing development. About the Model - Race-spec direct drive system equipped with rear ball differential for quick acceleration. - Double deck carbon fiber chassis features brand new 2mm upper deck, which is designed to help convert chassis roll into cornering speed, and 2.5mm lower deck. - R/C system, tires, body, motor, ESC, running battery & charger separately required. Some TRF415 MSXX Marc Rheinard Edition 2007 Specs: Lower Deck 2mm carbon fiber (same as MSXX) Upper Deck 2.5mm carbon fiber (new design) Damper Stay 3mm (same as MSX) Damper Support Carbon fiber (same as MSXX) Rear Upper Brace Separate type (new design) Front Unit Direct drive Center Pulley 16T Rear Unit Direct drive Diff. Pulley 36T Suspension Arm Reversible suspension Dampers TRF Dampers (new design) Suspension Pin Titanium-coated Screws Steel Air Scoop Included Wheel Axles Steel Bumper (same as TB Evo.5) Stickers (new design) |
