本帖最后由 Traxxas 于 17-9-3 12:08 编辑 TRAXXAS技术贴视频第十八期---TRX-4如何更换换挡舵机 视频原创发布者 BY TRAXXAS 翻译者 BY TRAXXAS中国总代理电波模型 因涉及到模型专业术语,如若翻译有误,欢迎指正! ![]() v.youku.com/v_show/id_XMzAwMTQ1MTI4OA==.html 以英文原档为准,请参考: How to Replace the Transmission Shift Servo | Traxxas TRX-4 Follow these step to replace the high low transmission servo in your TRX-4. You will just metric 2mm and 2.5mm hex tools and a pair of slide cutters. For easy access to the servo mounting screws, use a short L-shaped 2 mm hex tools. First, remove the body and make sure everything is powered off. Remove the battery tray by taking off the four screws securing it to the chassis. Remove the receiver box cover and the wire clamp. Remove the connector from the channel 3 slot and the receiver and pull the wire out of the receiver box. Use the side cutters to carefully cut and remove the small zip tie on the wire. Release the T-lock servo mounts that pull the wire through more easily. Use the tool to pop off the shift linkage from the servo. Remove the 2 screws to release the servo. Remove the 2 screws on the bottom of the chassis to release the ESC. This will allow you to remove the servo and the wiring. Carefully hold the servo horn and remove the screw to release it. Discard the old servo and then take your new servo and wrap the wire through the T-lock servo mount and into the receiver box. Plug the connector into the channel 3 slot and the receiver. Center the servo before installing it by powering on the transmitter and the vehicle. Make sure the rocker switch on the transmitter is flipped up to engage the low gear. With the spring and servo horn oriented like this, put the pieces you remove from the old servo onto the new one. With the spring and servo horn oriented like this, put the pieces you remove from the old servo onto the new one. Hold the servo horn firmly as you put the screw in. Be careful not to over tighten the screw. With the servo horn attached, you can remove the battery to power off the vehicle. Reinstall the 2 mounting screws to secure the new servo. Reattach the ESC with the 2 screws on the bottom of the chassis. Secure the T-Lock servo mount with the screws removed earlier. Replace the wire clamp and receiver box cover. Replace the battery tray and the hardware. Now your model is ready to go. 请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新! 如果您想了解更多关于我们品牌的资讯, 请咨询电波模型淘宝店旺旺客服: http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE 微信扫一扫,可得知最新资讯! ![]() ![]() 或联系我们 QQ :2713236907/270570161 手机:13790546054 王小姐 |
