TRAXXAS技术贴视频第十七期---Traxxas X-Maxx如何更换A臂 视频原创发布者 BY TRAXXAS 翻译者 BY TRAXXAS中国总代理电波模型 因涉及到模型专业术语,如若翻译有误,欢迎指正! ![]() ![]() 以英文原档为准,请参考: How to Replace a Suspension Arm | Traxxas X-Maxx To remove the suspension arm, first remove the wheel nut and wheel. “Tip: set the wheel under the chassis for easier access to pins and screws” Then remove the screws and pins from the end of the arm. Tap out the pins with the hex tool if needed. ”Tip: Use a pair of needle nose pliers to help remove the pins.”For the lower arms, For the lower arms, we will also need to remove the screw and pin holding the arm to the shock. Remove the worn or damaged arm and replace with the new one and re-insert the pins and screws. Now replace the wheel and you’re done. 请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新! 如果您想了解更多关于我们品牌的资讯, 请咨询电波模型淘宝店旺旺客服: http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE 微信扫一扫,可得知最新资讯! ![]() ![]() 或联系我们 QQ :2713236907/270570161 手机:13790546054 王小姐 |
