[遥控设备] futaba 的 2.4G也是自己变的吗?
查看: 3218|回复: 2| [复制链接]
bg1mcs 论坛元老 发消息
发表于 07-3-23 19:36:46 |显示全部楼层 来自: 中国北京
那为高手英文好帮助大概翻译一下
• No part of this manual may be reproduced in any form without prior permission.
• The contents of this manual are subject to change without prior notice.
• This manual has been carefully written. Please write to Futaba if you feel that any corrections
or clarifications should be made.
Before using your new 2.4GHz system, please read this manual thoroughly and use the
system properly and safely. After reading this manual, store it in a safe place.
1M23N17303
Contents and Technical Specifications
Your 2.4GHz system includes the following components;
Installing the PK-FSM2.4G/R603FS
[Specification]
• Communication method: One-way operation system
• Mode: PPM, HRS (Auto-detect)
• Maximum operating range: 80m (Optimum condition)
• For safety: F/S, B-F/S, ID (About 4billion ways of pair identifications)
PK-FSM2.4G;
• Transmission antenna: 1/2λ mono-pole
R603FS;
• Reception antenna: Diversity type (Two antennas: internal
and external)
• Power requirement: 6V Nicd battery
• DSC function available
• RS232C port: (for factory use only)
• Size: 39x26x14mm (excluding a projection part)
• Weight: 14.1g
PK-FSM2.4G Module
2.4GHz System
PK-FSM2.4G Module and
R603FS Receiver
Thank you for purchasing a PK-FSM2.4G module and an R603FS receiver. This system is
based on the combination of the newly developed 2.4GHz module and its correspondent
receiver. The system utilizes the 2.4GHz-SS radio communication and an ultra small antenna.
In addition, the system inherits Futaba's unique HRS (High Response System).
Features
2.4GHzSS (Spread Spectrum) radio communication system
Frequency channel setting unnecessary: Sifting the channels within the 2.4GHz band
automatically, this system minimizes the interference from other 2.4GHz system.
Accepts no unwanted signals by using ID code
The function “Auto-Detect” is utilized to automatically determine which mode is active,
HRS or PPM mode. (R603FS)
Short and small antenna (PK-FSM2.4G)/Diversity antenna (R603FS)
Applicable system; T3PK or T3VC Transmitter
R603FS Receiver
Module Cover for T3PK
Mini screwdriver
Install and adjust the PK-FSM2.4G module and R603FS receiver as described below.
Attachment of the module
CAUTION
Be sure to turn off the power of the transmitter before you attach
or detach the module.
1 Insert the module with care so that the connector pins of the
transmitter won't be bent.
WARNING
Adjust the antenna vertically to the ground. Otherwise, the operating
range may become shorter.
T3PK Transmitter
PK-FSM2.4G Module
Antenna
Module Cover
T3VC Transmitter
PK-FSM2.4G Module
Antenna
0 123456789
(Antenna Moving Range)
0
1
234567
8
9
INSTRUCTION MANUAL
For cars only
Usage Precaution
WARNING
Special attention should be paid before turning on the system
while other cars are running or other airplanes are flying because
the 2.4GHz RC system could potentially affect them.
WARNING
Be sure to set the Fail Safe function.
Repair Service
Before requesting repair, read this instruction manual again and recheck your
system. Should the problem continue, request repair service as follows:
Describe the problem in as much detail as possible and send it with a detailed
packing list together with the parts that require service.
• Symptom (Including when the problem occurred)
• System(Transmitter, Receiver, Servo's and model numbers)
• Model (Model name)
• Model Numbers and Quantity
• Your Name, Address, and Telephone Number.
If you have any questions regarding this product, please consult your local
hobby dealer or contact the Futaba Service Center.
FUTABA CORPORATION Phone: (043) 296-5118 Facsimile: (043) 296-5124
Makuhari Techno Garden Bldg., B6F 1-3 Nakase, Mihama-ku, Chiba 261-8555, Japan
©FUTABA CORPORATION 2006, 09 (1)
Receiver installation
Antenna
tube
Antenna
Coaxial
cable
R603FS
1 Install the R603FS receiver on the
car as follow;
Note: The operating range may become
shorter, although depending on where
the receiver and the antenna are
mounted.
WARNING
Install the antenna in the higher place as
shown in the figure.
Do not cut the antenna.
Keep the antenna away from the motor,
ESC and other noise sources as possible
as you can.
Put the antenna in the antenna tube to
protect it.
Do not bend the coaxial cable. It causes
damage.
Wrap the receiver with something soft such as foam rubber to
avoid vibration. If there is a chance of getting wet, put the receiver
in a waterproof bag or balloon to avoid water.
CAUTION
Always use R603FS under the following conditions;
Power supply; 6V Nicd battery (PPM/HRS mode)
Servo; 6V type Futaba Digital Servo (HRS mode)
* If the conditions are different, control is impossible or the servo may be damaged.
Frequency Range Setting
The frequency range of 2.4GHz system differs according to regulations
of the country that it is used in.
1 Use the rotary switches of the module to select the
frequency range mode.
0
1
2
3
4
5
6789
0: GENERAL
(2405.376MHz - 2477.056MHz)
8: FRANCE
(2407.424MHz - 2450.432MHz)
WARNING
If using this system in France, always use it to set the rotary
switch to "8".
* In other countries, both "0:GENERAL" and "8:FRANCE" are available.
How to turn on the power
A certain ID number is given to the receiver automatically. Identifying
this ID number, the system will minimize the interference from other
transmitters.
1 Bring the transmitter and the receiver close to each other
within one meter.
2 Turn on the transmitter.
Note: Check the LED on the module.
Parameter check for 0.5 seconds after power-on Red: On
Transmitting signals Green: On
F/S is activated by the tactile switch of the module.
(PPM mode) Green: Blink
Unrecoverable failure (EEPROM, etc.) Red and Green turn
on alternatively.
PCM is improperly selected. Red: Blink
3 Turn on the receiver.
4 Push the tactile switch of the receiver.
Note: Check the LED of the receiver.
No signal reception Red : On
Receiving signals Green: On
Receiving signals, but ID is unmatched. Green: Blink
on alternatively.
How to Set the F/S Position
PPM mode only:
*HRS mode: Set the F/S function by the transmitter.
1 Move and hold the throttle trigger (stick) to the F/S servo
position where you want to set (slow side) then push the
tactile switch on the module.
The LED blinks green.
Note: Always set again when turning on the power.
Battery F/S function
The Battery F/S function becomes active when the voltage of the
receiver becomes 4.75V or less. The throttle servo move to the preset
position.
Special Markings;
Pay special attention to the safety at
the parts of this manual that are
indicated by the following marks.
[Symbol] ; Prohibited ; Mandatory
Mark Meaning
Procedures which may lead to a dangerous condition and cause
death or serious injury to the user if not carried out properly.
Procedures which may lead to a dangerous condition or cause death
or serious injury to the user if not carried out properly, or procedures
where the probability of superficial injury or physical damage is high.
Procedures where the possibility of serious injury to the user is
small, but there is a danger of injury, or physical damage, if not
123_123 论坛元老 发消息
发表于 07-3-23 20:40:12 |显示全部楼层 来自: 中国江苏无锡
Sifting the channels within the 2.4GHz band automatically
是自动的,不过这个说明上的距离有点奇怪
最大操作范围 80M(最佳状况)
SPEKTRUM的2.4G说明上是3000ft,就是900M
gogoddd 高级 Fans 发消息
发表于 07-3-23 22:45:29 |显示全部楼层 来自: 中国北京
翻译
本说明书在未经允许的情况下不得擅自使用。
本说明书内容如有变动恕不另行通知!
本说明书已经北认真书写,如有错误请联系futaba!
在你使用本厂品之前,请仔细阅读说明书,在阅读之后把说明书妥善保管!
1M23N17303
内容以及技术参数:
您的产品包括以下组件:
包括发射模块PK-FSM2.4G和接受模块R603FS
[Specification]
规格:
通讯模式:单项控制系统
模式:ppm,hrs(自动选择)
最大控制范围80米(理想情况)
安全措施:失控保护,电池失控保护,身份认证(大约40亿的识别方式)
PK-FSM2.4G;
发射模块PK-FSM2.4G
传输天线:1/2λ 单极
R603FS;
接受模块R603FS
Reception antenna: Diversity type (Two antennas: internal and external)
接受天线:复合型(2跟天线包括内、外)
电源规格:6伏特镍铬电池
dsc功能
RS232C端口(仅工厂使用)
规格:39x26x14mm(不包含图出部分)
Weight: 14.1g
重量:14.1克
PK-FSM2.4G Module
PK-FSM2.4G模块
2.4GHz System
2.4GHz系统
PK-FSM2.4G Module and R603FS Receiver
PK-FSM2.4G模块和R603FS接收机
谢谢您购买了PK-FSM2.4G模块和R603FS接收机系统。本产品包含最新的发展的2.4GHz模块和对应的接收设备
           本产品应用了2.4GHz-SS无线电通讯系统以及配合易于携带的天线。
另外,本厂品应用了futaba的hrs系统。
Features
特性
2.4GHz-SS无线电通讯系统
无需屏率设定:在2.4GHz波段内自动选择,本系统最小花了与其他2.4GHz系统的干扰。
Accepts no unwanted signals by using ID code.
通过id编码接受信号
自动探测功能实现了HRS模式于PPM模式之间的任意切换。
发射机天线/接收机天线
可应用系统:T3PK or T3VC发射机
R603FS Receiver
R603FS接收机
3pk使用
Mini screwdriver
改锥
如以下方式安装PK-FSM2.4G模块/R603FS接受系统
模块的装配
CAUTION
注意
在装配以及差下之前关闭发射机电源。
安装模块时小心以防叉针弯曲。
WARNING
注意
发射机天线应垂直于地面,否测操作范围可能缩短。
T3PK Transmitter
t3pk发射机
PK-FSM2.4G Module
PK-FSM2.4G模块
Antenna
天线
Module Cover
模块盖子
T3VC Transmitter
T3VC发射机
PK-FSM2.4G Module
PK-FSM2.4G模块
Antenna
天线
0 123456789
(Antenna Moving Range)(天线移动位置)
0123456789
INSTRUCTION MANUAL
说明书
For cars only
仅对汽车有效
Usage Precaution
用前须知
WARNING
注意
在用其它器车运行和航空器飞行时本系统可能对他们产生潜在影响,所以在
应用本厂品是应注意
WARNING
注意
失控保护系统必须开启。
Repair Service(保修没用就算了)
? Symptom (Including when the problem occurred)
? System(Transmitter, Receiver, Servo's and model numbers)
? Model (Model name)
? Model Numbers and Quantity
? Your Name, Address, and Telephone Number.
?FUTABA CORPORATION 2006, 09 (1)
接收机安装
Antenna
天线
tube
天线管
Antenna
天线
Coaxial cable
同轴电缆
R603FS
接收机R603FS
安以下方式安装接收机R603FS
car as follow;
注意:控制范围可能变短,尽管这个取决于
接收机和天线的安装位置。
mounted.
WARNING
注意
参考图例把电线安装在高一些的位置
请勿剪短天线
尽量是天线远离马达、电变和其它噪声源头
as you can.
把天线放入管中以保护天线
protect it.
不要弯曲同轴电缆,这样可以引起损坏。
damage.
使用一些像泡沫乳胶一样的才智缠绕接收机以免她受震动。
如果遇到潮湿,应把接收机放到防水袋子或气球中使用。
CAUTION
注意
必须在以下情况使用R603FS接收机;
电源供应;6伏特
舵机;6伏特futaba数字多吉(hrs模式下)
如过不遵守使用规定,可能会失控或者舵机受损坏
频率范围设定
2.4GHz系统需按个国使用规定设置。
用模块上的旋转按钮选择频率范围。
0123456789
0: GENERAL(大都)
8: FRANCE(法国)
WARNING
注意
如果在法国使用本产品,务必选择“8”
switch to "8".
在其它国家,你可以选择0或8
如何启动电源
接收机北自动给于了一个特定的id编码。本系统在识别编码之后江最小花与其它设备的干扰。
transmitters.
把发射机和接收机距离一米放置。
within one meter.
打开发射机电源
注意:检查模块上的led指示灯。
在红灯点亮之后参数检查0.5秒
发射机信号等点亮
通过模块上的开关开启失控保护系统。
(ppm模式)绿灯:闪
操作失败(错误等)红灯或绿灯点亮。
on alternatively.
pcm是不正确的选择。红灯闪
打开接收机
推东接收机上的开关
注意:察看接收机上的led灯
无形号红灯
用信号绿灯
用信号但id编码不匹配。绿灯闪
操作失败(错误等)红灯或绿灯点亮。
on alternatively.
如何设置失控保护位置
PPM mode only:
仅对ppm模式
hrs模式:在发射机上设置失控保护
推动并保持油门推杆到你预设的失控保护位置然后开启模块上的开关。
led指示灯闪亮绿色。
注意:必须重新设置在开启电源之时。
电池失控保护功能
电池失控保护功能在接收机电池低于4.75伏特时被激活。油门舵机移至预设位置。
position.
Special Markings;(这个没用就算了)
Mark Meaning
