[电子设备] Much More Cell Master Platinum
查看: 4979|回复: 11| [复制链接]
发表于 07-3-19 02:41:44 |显示全部楼层 来自: 中国广东广州
Just when you thought you couldnt have any more products released from Much More today, along comes the updated CTX Cell Master, Platinum edition. A brand new state-of-the-art charger with improved hardware and featuring revised software, the Cell Master is the perfect battery management unit for Charging and discharging all Ni-MH & NiCD.
Hit more to see all the specs…
Main Features
Peak Charge - Super linear charge(3 memories-customizable)
CTX Charge - 1/3-2/3-3/3 step charge(3steps charge, 3memories-customizable)
Li-Ion & Polimer Charge - up to 11.1V(3cell), 1A charge, discharge
Discharge - 0.1~10A , 0.1~6.0V cutoff
Cycle - up to 3 times repeatition
Last Data - save CHG, DCH, CYC data
Input - DC 10.0-16V
Cell nunber - 1-8cells, 0.1-10A charge, 0.1-10A discharge
CM has current limit as belows.
Charge
1cell 0.1~5A
2cell 0.1~6.5A
3cell 0.1~8A
4-8 0.1~10A
Discharge
1~6cell 0.1~10A
7cell 0.1~8A
8cell 0.1~6A
- Cycle (1~3times), Latest data display.
- Peak sensitivity 3mV/ pack~99mV/ pack, Zero delta peak
- Auto start timer charge (count down)
- Auto repeak (0~3) comes with delay time and capacity limit
- Trickle (on/off) - 0.1A
- Flex charge (off~9steps)
- Temp. sensor included. (15~70deg.C)
- Temp. start(for cold batteries)
- Capacity cut, Temp cut, Peak cut, Negavolt (one of four messege is shown after charge)
- Key tones off~3,
- 3 kind of selectable melody for start, end, error.
- IC controlled cooling dual ball bearing fans.
- Charge Amp, capacity, delta peak, Temp. cutoff, fan starting Temp. values can be changed during Peak charge.
- Black back lit LCD, Gold plated alligator clips in/output, Blue state indicator LED
- Fan/Battery warmer control output
- Easy key operations
- Input and output protection against overloads, reverse polarity and short circuits,low or high input voltage, low battery temperature.
- Also, the auto restart system after power failure.
gogoddd 高级 Fans 发消息
发表于 07-3-19 23:20:53 |显示全部楼层 来自: 中国北京
翻译
你也许在想mm最近怎么没有推出新产品呢?现在一款mm推出的新版充电器就摆在你面前了——cell master白金版。一个融入最先进技术的充电器包括硬件的升级和校对功能软件的加入。对所有的镍氢和镍铬电池来说cell master是您不二的选择。
预知更多详情参阅以下资料:
主功能:
峰值充电模式:线性充电方式(3种自定义模式)
ctx充电模式:1/3-2/3-3/3渐进充电方式(3段充电,3种自定义模式)
Li-Ion & Polimer充电模式:最大11.1伏特(3粒电池)1安培冲、放电
放电模式:0.1-10安培 0.1-6.0伏特截止电压设置
循环模型:最多可设置3次循环
数据储存:充电、放电、循环数据
输入:10-16伏特
电池节数:1-8节 0.1-10安培冲、放电流设置
关于cell master电流限制参考以下数据:
充电
1粒 0.1-5安培
2粒 0.1-6.5安培
3粒 0.1-8安培
4-8粒 0.1-10安培
放电
1-6粒 0.1-10安培
7粒 0.1-8安培
8粒 0.1-6安培
循环(可设置1次到3次)只显示最近一次的数据
峰值灵敏度 3毫伏/节-99毫伏/节 零点三角峰值
自动充电设置(倒计时)
自动峰值设置要结合延迟时间和电池容量限制
连续补充充电(开/关) 0.1安培
曲线充电模式:关-9段(因为没用过mm的设备这个不懂)
温度感应器:15-70度
温度启动装置(仅对低温电池)
容量限制、温度限制、电压限制、峰值限制(其中任何一个信息在充电后显示)
安键声音(关-3)开始,结束,错误可选3种音乐
冷却系统由IC芯片组控制
在峰值充电时可设置充电安数、电池容量、零点三角峰值、温度、终止、风扇启动温度。
黑色表面及背光LCD,输入/输出端均配鳄鱼夹,蓝色led状态指示灯
电扇/电池温热装置控制
输入/输出端过载保护,短路,断路保护等
在电源启动失败时重启系统
gogoddd 高级 Fans 发消息
发表于 07-3-19 23:23:16 |显示全部楼层 来自: 中国北京
Black back lit LCD应该是黑色背光LCD显示
AI 超级元老 发消息
发表于 07-3-20 00:26:25 |显示全部楼层 来自: 中国上海
原帖由 gogoddd 于 2007-3-19 11:23 PM 发表
准确的说是和限量版一样的黑色LCD+白字
少了一句- Easy key operations 简单的按键操作
应该是-输入和输出端过载,反接和短路,过低或过高输入电压,电池温度过低保护
[ 本帖最后由 AI 于 2007-3-20 12:31 AM 编辑 ]
momomomo 终极 Fans 发消息
发表于 07-3-20 17:56:37 |显示全部楼层 来自: 中国四川成都
据说Much More的噪音挺大,现在出的有改善吗?
bbbb 超级元老 发消息
发表于 07-3-20 21:21:32 |显示全部楼层 来自: 中国上海
原帖由 gogoddd 于 2007-3-19 23:20 发表
连续补充充电(开/关) 0.1安培
涓流(开/关)0.1A
脉冲模式:关~9段
gogoddd 高级 Fans 发消息
发表于 07-3-20 21:59:33 |显示全部楼层 来自: 中国北京
各位都懂怎么不翻译呢
各位都懂怎么不翻译呢???
jetso 论坛元老 发消息
发表于 07-3-20 22:29:50 |显示全部楼层 来自: 中国广东广州
原帖由 gogoddd 于 2007-3-20 01:59 PM 发表
各位都懂怎么不翻译呢???
你都会说看懂了, 何苦还去翻译呢. rcfans上很多朋友的英文都没问题的
feng 超级元老 发消息
发表于 07-3-21 01:29:13 |显示全部楼层 来自: 中国广东广州
那还可以控制电池加热器吗?
就是那个什么电池温度启动功能吗?
发表于 07-3-21 01:44:20 |显示全部楼层 来自: 中国广东广州
控制冷却风扇 和加温器  这两个功能确实比较创新的
